Hammer7 Posted August 19, 2021 Share Posted August 19, 2021 CA has produced a really good video on getting the framing just right. Does anyone have others to add for efficient editing to get framing as exact as possible? Link to comment Share on other sites More sharing options...
parkwest Posted August 19, 2021 Share Posted August 19, 2021 52 minutes ago, Hammer7 said: CA has produced a really good video on getting the framing just right. Does anyone have others to add for efficient editing to get framing as exact as possible? Do you have a link to this video? Link to comment Share on other sites More sharing options...
Hammer7 Posted August 20, 2021 Author Share Posted August 20, 2021 Link to comment Share on other sites More sharing options...
Hammer7 Posted August 20, 2021 Author Share Posted August 20, 2021 FRAME DETAILING.pdf Link to comment Share on other sites More sharing options...
GeneDavis Posted August 20, 2021 Share Posted August 20, 2021 Exact. https://3d-viewer.chiefarchitect.com/go?share=453127181375659 1 Link to comment Share on other sites More sharing options...
Hammer7 Posted August 20, 2021 Author Share Posted August 20, 2021 Thank you Gene, I have not used that yet, that would be very helpful in certain circumstances. Link to comment Share on other sites More sharing options...
rgardner Posted August 20, 2021 Share Posted August 20, 2021 Only thing that I can add as a tip that might help is when you are editing framing manually make good use of cad lines, extend objects, and cut objects tools to trim and lengthen multiple framing members at the same time. Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 21, 2021 Share Posted August 21, 2021 12 hours ago, GeneDavis said: Exact. https://3d-viewer.chiefarchitect.com/go?share=453127181375659 may I ask why the rafter tails attached to the trusses, instead of proper trusses? Link to comment Share on other sites More sharing options...
GeneDavis Posted August 21, 2021 Share Posted August 21, 2021 Because the trusses have 2x8 top chords and the builder wanted it this way. Link to comment Share on other sites More sharing options...
Hammer7 Posted August 24, 2021 Author Share Posted August 24, 2021 This is an in-progress framing plan, the left side generated in the correct location, the redline clouds all justified to the inside of the mud/sill, .....why? framing.pdf Link to comment Share on other sites More sharing options...
SH_Canada Posted August 26, 2021 Share Posted August 26, 2021 That is odd, I assume floor walls line up? Might need to post the plan Link to comment Share on other sites More sharing options...
