MN_JohnH Posted July 27, 2021 Share Posted July 27, 2021 I am wondering how I can set up my foundation walls and main floor so that I can have a slab on one part and a framed floor on the other that flush out at the same level. But I would like the top of the ICF foundation walls to have a double sill plate with the concrete poured inside of that where the slab is and the other side would have accommodations for the framing to come out at the same height. I have a simple plan attached and some cross section details of how the top of foundation wall would look. I know I can just build it with the slab at the same level as the house and then just have these detail drawings included in the plan but I am wondering if there is a way to actually have Chief build it this way? plan.plan Link to comment Share on other sites More sharing options...
mtldesigns Posted July 28, 2021 Share Posted July 28, 2021 Can you put a room divider to separate the two different types of foundation, then change in the dbx? Link to comment Share on other sites More sharing options...
SH_Canada Posted July 28, 2021 Share Posted July 28, 2021 4 hours ago, MN_JohnH said: so that I can have a slab on one part and a framed floor on the other the screenshots you have show both floors as slab. I'm not understanding what you are trying to do, from an absolute elevation perspective. It's almost like you have a walkout basement with a stepped foundation, if the slabs are at the same elevation, but the stem wall below the slab varies from only a footing to what looks like about 3'? Link to comment Share on other sites More sharing options...
rgardner Posted July 28, 2021 Share Posted July 28, 2021 I believe what you are looking for is called a hung joist floor system. Open the foundation wall you want to have the floor system hung from and check the options in the structure panel of the wall dbx. Link to comment Share on other sites More sharing options...
MN_JohnH Posted August 19, 2021 Author Share Posted August 19, 2021 I guess the plan I sent was confusing because I tried to draw something simple to illustrate since my actual plan was to big. Let's just start with this question: How can I make an ICF wall that goes down to frost footing with a double plate on top and the top of the slab floor is level with the top of the double plate? I have a detail attached. ached. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 19, 2021 Share Posted August 19, 2021 15 hours ago, MN_JohnH said: I guess the plan I sent was confusing because I tried to draw something simple to illustrate since my actual plan was to big. Let's just start with this question: How can I make an ICF wall that goes down to frost footing with a double plate on top and the top of the slab floor is level with the top of the double plate? I have a detail attached. With a special Wall Definition it is possible, though I am not sure what other issues it may cause down the line. The biggest issue will be that you want the bottom of the slab 1" below the top of the Stemwall as Chief Automatically wants to place the Slab on the Stemwall due to the way chief uses Rooms and the bottom of the floor structure. The simple fix is to spec the floor slab at 3" in the room/floor settings and the use a 4" CAD box in Cross Sections though. ( 3rd pic ) ALT. Wall Def. Link to comment Share on other sites More sharing options...
MN_JohnH Posted August 24, 2021 Author Share Posted August 24, 2021 Thanks, I am not sure what you are doing with the wall definition specs here. But let's even go more basic than this: how do I draw a slab inside ICF walls with no crawlspace or anything underneath, just fill? And then how do I put a double treated plate on top of my ICF wall? Link to comment Share on other sites More sharing options...
