Last time I needed the Help File it was not there. Just had time to check it again and the window pops up but nothing in it.
Anyone else having issues or figured out how to resolve them ?
Working here, windows help file is C:\ProgramData\Chief Architect Premier X13\Help\Default.htm
See if that shows in a browser. If it does then I'd reboot, have had a few odd things that were fixed that way.
Ok I guess that is the back door but it basically gets me the same thing as F1.
I have booted several time or possibly 100 times since I first noticed the issue so I don't think that will help.
Should I rerun the Help.exe  by itself or call tech support tomorrow ?
no corruption here CS.
image.thumb.png.080c586e10c3bb3365204fa98703b190.pngimage.thumb.png.9a559e59be471282abb99cf4196c45f2.png
However there is more info ( Log) in your User Folder > AppData > Roaming CA X13 Help...and it looks like mine is having issues with Translations
Info: HelpViewer log:  "Wed Jul 14 19:16:47 2021"
Debug: Application args:  ("C:\\Program Files\\Chief Architect\\Chief Architect Premier X13\\Chief Architect Premier X13 Help.exe", "127.0.0.1", "61131", "file:///C:/ProgramData/Chief Architect Premier X13/Help/Default.htm", "-id=0")
Warning: Installed Qt WebEngine locales directory not found at location C:/Program Files/Chief Architect/Chief Architect Premier X13/translations\qtwebengine_locales. Trying application directory...
Warning: Qt WebEngine locales directory not found at location C:/Program Files/Chief Architect/Chief Architect Premier X13\qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
Info: Loading of URL ' QUrl("file:///C:/ProgramData/Chief Architect Premier X13/Help/Default.htm#cshid=0") ' finished  successfully.
*** Folder and File Do not exist , hence the logged error in my case --- only using english though....
Also more info in
User Folder > AppData > Local > CA Inc > CA X13 Help >
User Folder > AppData > Local > CA X13> CA X13 Help >
Perhaps try a "Repair" from Control Panel>Programs and Features.............
KB
Interesting...   It seems like I have all the installed files you have but something must be corrupted.
See if a Repair can fix it ...otherwise a full reinstall perhaps....
Folders all have Folders within?  not empty eg
Ok thanks guys.  My folders do contain what seems to be all the required files or at least they are not empty shells.
I will see if tech is aware of the issue since it is why I called them last time because I could not access the file but forgot to mention that fact.
a "Repair" didn't help then?
No I did not try, is that an option when running the .msi file again ?
you skim reading again :)
KB
running the .msi file again will sometimes make the same offer too :)
KB
Yes that worked.  Thank You
    29829
    MeganB
    MeganB
