EStewart71 Posted May 19, 2021 Share Posted May 19, 2021 I'm pretty new to chief and am having a hard time figuring out how to create my foundation walls (8" CMU w/ brick) so that my 1st floor walls align over the brick rather than the main foundation layer (block). Can someone point me in the right direction? Link to comment Share on other sites More sharing options...
javatom Posted May 19, 2021 Share Posted May 19, 2021 The wood walls should align to the the foundation NOT the brick. Think of the brick as a facade. It does not support the walls above it. Link to comment Share on other sites More sharing options...
Solution rgardner Posted May 19, 2021 Solution Share Posted May 19, 2021 1 hour ago, EStewart71 said: I'm pretty new to chief and am having a hard time figuring out how to create my foundation walls (8" CMU w/ brick) so that my 1st floor walls align over the brick rather than the main foundation layer (block). Can someone point me in the right direction? There are lots of variables but 99% of the time it is your wall definition not set to align to the right points. Without a plan or pictures of the wall definitions for both your foundation walls and upper walls no one will be able to definitively help you. Link to comment Share on other sites More sharing options...
EStewart71 Posted May 19, 2021 Author Share Posted May 19, 2021 27 minutes ago, javatom said: The wood walls should align to the the foundation NOT the brick. Think of the brick as a facade. It does not support the walls above it. The brick is a structural member as long as installed with Type S mortar and supported by the footing. While it doesn't have to be a structural member the brick certainly can be. See the image. Link to comment Share on other sites More sharing options...
EStewart71 Posted May 19, 2021 Author Share Posted May 19, 2021 25 minutes ago, rgardner said: There are lots of variables but 99% of the time it is your wall definition not set to align to the right points. Without a plan or pictures of the wall definitions for both your foundation walls and upper walls no one will be able to definitively help you. Thanks Ryan. It was my wall definition. I moved my brick to my main layer with my block foundation wall and was able to line it up. I had previously had it in my exterior layer. I appreciate the response. Link to comment Share on other sites More sharing options...
javatom Posted May 19, 2021 Share Posted May 19, 2021 4 hours ago, EStewart71 said: The brick is a structural member as long as installed with Type S mortar and supported by the footing. While it doesn't have to be a structural member the brick certainly can be. See the image. It might be a little hard to install seismic hardware etc. with this set up. Link to comment Share on other sites More sharing options...
joey_martin Posted May 20, 2021 Share Posted May 20, 2021 16 hours ago, javatom said: It might be a little hard to install seismic hardware etc. with this set up. We don't all live and work in seismic zones. Link to comment Share on other sites More sharing options...
javatom Posted May 20, 2021 Share Posted May 20, 2021 I would imagine that all areas would need bolts to secure the bottom plate. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 20, 2021 Share Posted May 20, 2021 3 hours ago, javatom said: I would imagine that all areas would need bolts to secure the bottom plate. That was my first thought when I looked at this detail; either an anchor bolt, Simpson plate connector -- something. I'm sure the OP just didn't show the anchor. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 21, 2021 Share Posted May 21, 2021 8 hours ago, javatom said: I would imagine that all areas would need bolts to secure the bottom plate. not with the ladder method of cribbing as you can then nail away on the ladder... or if an engineer says you do not need it Link to comment Share on other sites More sharing options...
joey_martin Posted May 21, 2021 Share Posted May 21, 2021 There are multiple anchoring options other than the ole cast-in-place anchor bolt. Link to comment Share on other sites More sharing options...
