Aligning Walls Over Brick
EStewart71
Go to solution Solved by rgardner,
I'm pretty new to chief and am having a hard time figuring out how to create my foundation walls (8" CMU w/ brick) so that my 1st floor walls align over the brick rather than the main foundation layer (block). Can someone point me in the right direction?
  • Solution
There are lots of variables but 99% of the time it is your wall definition not set to align to the right points.  Without a plan or pictures of the wall definitions for both your foundation walls and upper walls no one will be able to definitively help you.
27 minutes ago, javatom said:
The wood walls should align to the the foundation NOT the brick.  Think of the brick as a facade.  It does not support the walls above it.
The brick is a structural member as long as installed with Type S mortar and supported by the footing. While it doesn't have to be a structural member the brick certainly can be.  See the image.
Brick-faced foundations - Fine Homebuilding
Thanks Ryan. It was my wall definition. I moved my brick to my main layer with my block foundation wall and was able to line it up. I had previously had it in my exterior layer. I appreciate the response.
It might be a little hard to install seismic hardware etc. with this set up.
3 hours ago, javatom said:
I would imagine that all areas would need bolts to secure the bottom plate.
That was my first thought when I looked at this detail; either an anchor bolt, Simpson plate connector -- something. I'm sure the OP just didn't show the anchor.
