bjp2022 Posted April 3, 2021 Share Posted April 3, 2021 Hello, I have an odd glitch or error that is driving me nuts. When I change my material type or wall types on the home I am working on the terrain will no longer generate correctly. Its like the house is not there. From the image attached below you can see the terrain is now inside my house. The file is too large to attach, but I am hoping someone might be able to point me in the right direction. I have tried deleting the terrain and add it back in, but it does not seem to work. Its as if the house perimeter that defines the area for the program to cut the terrain is gone. Thanks Link to comment Share on other sites More sharing options...
MPDesign Posted April 3, 2021 Share Posted April 3, 2021 open terrain dbx and make sure the check mark at the bottom to clip terrain to the house is on. Link to comment Share on other sites More sharing options...
bjp2022 Posted April 3, 2021 Author Share Posted April 3, 2021 Hello MPDesign, I am using x11, and are you talking about Hide terrain intersection building check box? If so yes its checked. Link to comment Share on other sites More sharing options...
MPDesign Posted April 3, 2021 Share Posted April 3, 2021 For a quick fix, I would try a terrain hole positioned around the house. I would need a plan copy to determine for sure. 1 Link to comment Share on other sites More sharing options...
bjp2022 Posted April 3, 2021 Author Share Posted April 3, 2021 The terrain hole works as a solution. It would take me a bit of time to reduce the file size down. I have a feeling for some reason the program is just not autogenerating the terrain hole for the house. Thanks for our assistance. Link to comment Share on other sites More sharing options...
joey_martin Posted April 3, 2021 Share Posted April 3, 2021 What level did you build the terrain on? Link to comment Share on other sites More sharing options...
bjp2022 Posted April 3, 2021 Author Share Posted April 3, 2021 Sorry I had to step away for an issue that came up. I was able to reduce the size by zipping it (took a long time to upload, 30min!!). Note the file I attached has a terrain hole in it, but if you delete it (its on the terrain features layer). The elevation data is on terrain elevation data and in the 3d view the terrain is on terrain perimeter (which was the default from the program). Upload failed and did not get notification until after. Going to attempt again.. Link to comment Share on other sites More sharing options...
Mark3D Posted April 3, 2021 Share Posted April 3, 2021 that model needs a terrain hole as your terrain is quiet steep and its surface shows up on multiple floors so chief is can not clip correctly Link to comment Share on other sites More sharing options...
bjp2022 Posted April 3, 2021 Author Share Posted April 3, 2021 Thanks everyone for your help. The terrain hole works perfectly and its a 30second fix. Link to comment Share on other sites More sharing options...
Dermot Posted April 4, 2021 Share Posted April 4, 2021 This is just an FYI for those that are interested... Sometimes when you have terrain generating inside the building it is because your walls are not properly connected or one or more of them is marked as No Room Definition. Fixing these problems will often correct the problem with the terrain. The program is not always going to be able to handle every possible situation and might not cut the terrain hole exactly the way you want it to. In these situations creating your own manual terrain hole is usually the easiest way to solve the problem. If you select the terrain perimeter, you can use the "Make Terrain Hole Around Building" tool to generate the default hole and then edit the shape as needed. 1 1 Link to comment Share on other sites More sharing options...
Mark3D Posted April 4, 2021 Share Posted April 4, 2021 When i was looking at your file i noticed you had terrain data on top of terrain data there is a elevation region in front of garage if you keep the elevation region and remove the elevation lines in the same space as your elevation region buy doing a complete break and deleting the over lapping data your terrain will behave much better you should never have multiple elevation data in the same space Link to comment Share on other sites More sharing options...
bjp2022 Posted April 4, 2021 Author Share Posted April 4, 2021 Hey Mark, yes I agree. Based on reading some of the forms most people recommend the same. Right now its seems to be working out OK for my purposes, but I may have to clean it up if things start to act up again. Just creating a terrain hole for the house and garage cleaned it up. Thanks again! Link to comment Share on other sites More sharing options...
rlackore Posted April 5, 2021 Share Posted April 5, 2021 On 4/3/2021 at 8:03 PM, Dermot said: If you select the terrain perimeter, you can use the Make Terrain Hole Around Building tool to generate the default hole and then edit the shape as needed. Thanks for this nugget - I didn't know that tool existed. I always use manual terrain holes to fine-tune things, and this tool will save some time. Link to comment Share on other sites More sharing options...
