ChiefRoland Posted February 26, 2021 Share Posted February 26, 2021 Hello: No matter what I do (elevation lines, points, floor defaults, etc.) I can't get the terrain to line up to the top of my stem wall. (see pic) What am I doing wrong? Any suggestions are greatly appreciated. Link to comment Share on other sites More sharing options...
Mark3D Posted February 26, 2021 Share Posted February 26, 2021 Upload your plan would help you might have intersecting terrain elevation data or you have just not told the terrain to rebuild after you added the data it’s hard to tell with out the plan file Link to comment Share on other sites More sharing options...
joey_martin Posted February 26, 2021 Share Posted February 26, 2021 You need to move the overall elevation distance from the 0'-0" spot. All those terrain lines get the info from the main distance from 0'-0" Link to comment Share on other sites More sharing options...
ChiefRoland Posted February 26, 2021 Author Share Posted February 26, 2021 Thank you both for your replies. I'm not at liberty to upload the plan, but my elevation data if very simple (no crossing lines) and the terrain is up-to-date. I didn't really understand Joey's reply or how to accomplish what he's suggesting. Again, thank you. P.S. I have a feeling that this is some configuration issue with the building itself, but I don't know what. Link to comment Share on other sites More sharing options...
ChiefRoland Posted February 26, 2021 Author Share Posted February 26, 2021 Thank you solver... you solved it! I could've sworn I played with that before, but in any case, this is what controls it. Do you know what that value is relative to? Is it some average terrain elevation? Again, thank you. Link to comment Share on other sites More sharing options...
ChiefRoland Posted February 26, 2021 Author Share Posted February 26, 2021 Yeah I read it smart Alec, but the terrain is not all the same elevation. So I don't know if it means "above terrain average elevation" or "above terrain lowest point" or "above terrain highest point" 4 Link to comment Share on other sites More sharing options...
glennw Posted February 26, 2021 Share Posted February 26, 2021 Quote Yeah I read it smart Alec, but the terrain is not all the same elevation. So I don't know if it means "above terrain average elevation" or "above terrain lowest point" or "above terrain highest point" Have you read the help file? It is all explained there. 2 Link to comment Share on other sites More sharing options...
joey_martin Posted February 27, 2021 Share Posted February 27, 2021 5 hours ago, ChiefRoland said: Do you know what that value is relative to? The sub-floor.....0'-0" 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 15, 2021 Share Posted May 15, 2021 On 2/26/2021 at 9:03 PM, joey_martin said: Do you know what that value is relative to? It is actually relative to elevation 0 from what I can tell. The label is misleading, it is only "subfloor height above terrain" if your subfloor elevation is at 0". i.e. if I set my subfloor to be at 36" (in the structure panel of the main floor), this parameter is then set to 0 (grade level), assuming 36" is 36" above grade at the point you are choosing as your reference point. Room structure elevations are referenced to "Something". it does not have to be the main floor subfloor. it can be whatever you deem zero to be. in the case below I deem zero to be elevation of grade, main floor is 33" above. I do this because that is how I think. i.e. I need 12" of basement wall to be above grade. And when I measure an as built, it is from grade, so I can see the elevations in the structure easily without having to do a storey pole on an elevation, or to do the math. I believe most do not do it this way, most put 0 as main floor subfloor, and adjust the storey pole ground elevation. of course on a sloped lot, this reference then has to be grade somewhere. For me, it is typically the front door On 2/26/2021 at 3:25 PM, ChiefRoland said: Yeah I read it smart Alec, but the terrain is not all the same elevation. So I don't know if it means "above terrain average elevation" or "above terrain lowest point" or "above terrain highest point" it is the terrain object elevation, not contours. Link to comment Share on other sites More sharing options...
