SteveNovato
Appliance Placement Issue
Good Morning All,
I am trying to finish a very simple kitchen plan. My issue is with a full height cabinet with two separate appliances installed (built in oven and built in microwave). The 3D view and Cross section accurately show what I want the finished item to look like. But...in the plan view, the microwave symbol sticks out in front of the cabinet. I could cover this with a CAD box, but I would really like to know how to fix this. I have tried moving the (X,Y & Z) positions in the edit symbol DBX, though the position on the plan is always different from the other views (if the microwave symbol looks correct in plan view, the 3d view view will show the appliance face at the back of the cabinet opening).
I have restarted Chief, as well as the computer, only to have the same results. Also, please excuse the line weights in the cross section pdf.
I would really appreciate input on how to solve this issue.
Thanks, Steve
153 View.pdf
153 Cross Section.pdf
153.plan
For the freestanding microwave, you're overthinking it a bit.  No need for any offsets.  Put those back to zero and just put the microwave where it goes.  You'll need to temporarily override bumping and pushing by either toggling it off or by holding down the Control key.
Steve, your X, Y, Z plan placement should all be at 0 (first image) and your X, Y, Z symbol origin should also be at 0 (third image). You can access the symbol origin with the "chair" symbol you see when you select the item (second image)
Done. Thank you for the great instructions...I don't know how the position strayed from zero, but I won't be fooled again!
The symbol was probably made to be inserted into a cabinet as an integrated appliance and not as a freestanding appliance as you were using it.  when an appliance is included as part of the cabinet then you have to set that Y offset and the bounding box depth to match this number…
This is a generic video about multiple appliances in a single cabinet.
This one is specific to your plan.
All of your tips were very useful.
Eric, your video is above and beyond! Thank you
Sometimes I feel that being a member of Mensa should be a prerequisite for this program.
    29356
    PattyS68
    PattyS68
