Csnrv2019 Posted January 20, 2021 Share Posted January 20, 2021 Friends I went to open a plan this morning and have found a glitch with the program. Whenever I try to run the program or open a plan it simply does nothing. I have tried to run as administrator, repair the file, verified the update, uninstalled and reinstalled and I am still unable to open the program. No error codes, no dialogue boxes, or any notifications. Support doesn't open for another couple of hours so I thought I would see if anyone here may have a fix or another thought on what I should check to get it running. Thanks in advance for your time. Mike Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 20, 2021 Share Posted January 20, 2021 Can you open any plans, new plan etc or is it a single plan file that you cannot open (All or nothing???) DJP Link to comment Share on other sites More sharing options...
Csnrv2019 Posted January 20, 2021 Author Share Posted January 20, 2021 unable to open any plans, can't even open the program to start a new plan. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 20, 2021 Share Posted January 20, 2021 Been using since Version Four, never had this happen nor have I heard of it happening to anyone. Your best bet is to contact Tech Support when they open, sorry. DJP Link to comment Share on other sites More sharing options...
lbuttery Posted January 20, 2021 Share Posted January 20, 2021 did you reboot the PC ? was it working yesterday ? did Windows do an update ? can you reverse that update ? Lew Link to comment Share on other sites More sharing options...
Csnrv2019 Posted January 20, 2021 Author Share Posted January 20, 2021 Yeah I have never had a problem like this either. I will be calling when they open. Thanks I have restarted several times, I have been out for 3 weeks so it hasn't been used for a while. Unsure if any updates to windows has caused it since it has been so long. Thanks anyway, I will just wait on support to open. Link to comment Share on other sites More sharing options...
joey_martin Posted January 20, 2021 Share Posted January 20, 2021 I got a notification that I have windows updated waiting to be installed. Is you PC set to auto update? Link to comment Share on other sites More sharing options...
Csnrv2019 Posted January 21, 2021 Author Share Posted January 21, 2021 So just to update everyone on what we discovered with this error. I updated my signature to reflect the current system I am using! With that being said I was using a Dell Thunderbolt docking station prior to receiving the 49" Dell Monitor in November. The limitations of that docking station would not allow me to have the 3 monitors connected at all times, so I then purchased a Startech.com docking station that would support this setup of monitors. Unannounced to me at the time the station uses Displaylink technology via 2 display ports that when running everything I use besides Chief Architect was working fine. Due to holidays and covid, I returned to work yesterday, and when you open CA the program detects the system is not meeting the minimum requirements to operate. If I disconnect the monitors from the display ports and only use the HDMI connected monitor the program loads and I can then connect the other 2 monitors and use the program. However, I was told that if I tried to render or do some other tasks it would most likely crash the program and would have to restart, thus lose recent work as well possibly. So if anyone is looking at using a docking station with their setup, I wanted to bring to your attention, the possible limitations of such a setup and a costly miscalculation! I would be glad to discuss further if needed and am going to start another thread with this information for easier finding in the future for others who may be researching uses of docking stations in their setup. Hope this helps someone, stay safe, and thanks! 1 Link to comment Share on other sites More sharing options...
Csnrv2019 Posted January 21, 2021 Author Share Posted January 21, 2021 I just updated the tags on this thread so if someone thinks I should do something else to make it more visible just let me know. Thanks Link to comment Share on other sites More sharing options...
Ridge_Runner Posted January 21, 2021 Share Posted January 21, 2021 Thanks for the follow-up. Link to comment Share on other sites More sharing options...
CreativeHomes Posted February 27, 2023 Share Posted February 27, 2023 Thank you. You saved me a lot of headache. My docking station was working fine, until it didn't. Link to comment Share on other sites More sharing options...
