myrtsbnye 2 Posted January 19 Is there a way to add a double top railing as shown in the attached pic? Or should I just either add it in manually or make a symbol? Share this post Link to post Share on other sites
Chopsaw 661 Posted January 19 That particular railing style could be built as a panel railing in Chief. https://www.chiefarchitect.com/support/article/KB-02893/creating-custom-balusters-and-railing-panels.html Or add a p-solid top rail since your mid posts will need to be done manually as well. Share this post Link to post Share on other sites
Ridge_Runner 131 Posted January 19 Molding polyline for the top rail and adjust offsets if necessary. Share this post Link to post Share on other sites
glennw 1027 Posted January 19 You could use a Post To Beam railing and reduce the deck ceiling height to the overall height of your rail. Plus some other tweeks to get the sizes and configuration you want. Share this post Link to post Share on other sites
Chopsaw 661 Posted January 19 1 hour ago, Ridge_Runner said: Molding polyline for the top rail and adjust offsets if necessary. That comment always seems to come up but what do you do about your construction documentation ? Draw cad boxes where the p-solids would be ? Just now, glennw said: You could use a Post To Beam railing and reduce the deck ceiling height to the overall height of your rail. Plus some other tweeks to get the sizes and configuration you want. Looks good Glen but be careful if that deck is attached to another structure. Share this post Link to post Share on other sites
glennw 1027 Posted January 19 1 minute ago, Chopsaw said: Looks good Glen but be careful if that deck is attached to another structure. What is the problem? Share this post Link to post Share on other sites
Chopsaw 661 Posted January 19 If I recall correctly the reduced ceiling height can wreak havoc with the truss system in certain situations but they may have fixed it. Share this post Link to post Share on other sites
robdyck 497 Posted January 19 4 hours ago, myrtsbnye said: Is there a way to add a double top railing as shown in the attached pic? Or should I just either add it in manually or make a symbol? It doesn't get much quicker or easier than making your own double top rail using a 2x4 and 2x6 profile with a 3.5" gap. Add to library as a stacked molding. One drawback to get it exactly like the picture is the intermediate 4x4 posts won't build like the image. I'd add those manually. Share this post Link to post Share on other sites
robdyck 497 Posted January 19 @myrtsbnye Deck Railing, Lumber.calibz Share this post Link to post Share on other sites
Ridge_Runner 131 Posted January 20 2 hours ago, Chopsaw said: That comment always seems to come up but what do you do about your construction documentation ? Draw cad boxes where the p-solids would be ? Not sure I follow the question? They show fine in section and 3D. The mid-posts will have to be manual as you said. Share this post Link to post Share on other sites
Chopsaw 661 Posted January 20 2 hours ago, Ridge_Runner said: Not sure I follow the question? They show fine in section and 3D. I was thinking more of the plan view representation that is not very good with most Molding Lines or Polylines. Maybe you are not using that at all and relying on the railing wall Plan Display options ? Share this post Link to post Share on other sites
Ridge_Runner 131 Posted January 20 15 hours ago, Chopsaw said: I was thinking more of the plan view representation that is not very good with most Molding Lines or Polylines. Maybe you are not using that at all and relying on the railing wall Plan Display options ? That's what I usually do. 1 Share this post Link to post Share on other sites
