HaroonMalik
Area display both in imperial and metric
Hi This refers to attached image. I am just wondering if room area display possible both in sq ft and sq meter at the same time just like shown in dimension? Its possible in Revit though. Your help much appreciated!
Custom macros in a text box are one easy way.  Cut and paste this into your room for an idea...
Imperial Area = %room.standard_area.to_sq_ft.round% sq ft
Metric Area = %room.standard_area.to_sq_m.round(2)% sq m
Just saw your picture.  That's a different thing.  For that, open your dimensions and use the Secondary Format.  Check Include Second Format and select the desired formatting.
Hi Alaskan,
Thank you for your help. Unfortunately I did not get you.
I want the area to be displayed in both formats simultaneously same like dimensions displays in both formats. Like 92 Sq Ft / 8.54 Sq M. Refer attached image.
Thank you.
Thank you.
Read my first post again.
3 hours ago, HaroonMalik said:
Hi Alaskan,
Thank you.
I’m no macro genius, but here’s my method:
1) select room and “make room polyline” (I put these polylines on a separate layer so I can turn them on and off)
2) In the “label” of the polyline specify a “user Defined label from the list” (a macro that you’ll create in step 3)
3) now you need to create a macro for that list:
        3a) Go to menu > CAD > Text > Text Macro Management > New
        3b) >Name: Give your macro a Name, ex. roomAreaMetric
        3b) >Value:  “((area)*(0.9290304)).round(2)” <- type the crap between the quotes, don’t ask.
        3c) > check “Evaluate”
        3d) > Context = “Owner Object”
        3e) > OK
Your polyline will have the area in metric rounded to 2 decimal places. (that’s what the “2” is in the “round(2) part of the formula.
If you want both imperial and metric in the same polyline label then you can add a second line in the polyline label which is just:
“%area.round% sq.ft”
What Michael posted above, but, what's between the % signs needs to be lower case.
There’s nothing wrong with the ALL CAPS. I did that on purpose because that’s the format the OP was using.
EDIT:  I see based on some of the follow-up conversation below that this needs some clarification.  The text I posted above is not truly capitalized letters.  It's Rich text formatted to Uppercase.  So I guess you are in fact correct.  The macros need to be typed in lowercase.  You should however still be able to simply copy and paste what I posted above because what you see is only formatting.
        3e) > OK
Your method is WAY over complicated.  You should read my first post too.
My way is definitely convoluted but I need to be able to control those independently of the room size. As in, stretch a polyline to see what area it gives before I make a modification to a room or area.
I also forgot a decimals place in my calculation.
However your calculation doesn’t return the correct area. I copied and paste and got 6.97 sq m instead of 5.2 sq m in my little plan.
Nevermind mind I changed “standard” to “internal” to get the inside square footage.
Your method also allows to control the text more freely since my way uses polylines and therefore is stuck in that dreaded “polyline, labels” hell.
Generally you shouldn't argue with Michaei (Alaskan Son) when it comes to macros.  - or me either for that matter :lol:
I would have posted the same solution as he did, but I would probably have made it a bit more bullet proof so that it wouldn't indicate an error if not attached to a room - just my preferred way of coding.
51 minutes ago, solver said:
No doubt I'm doing something wrong.
ct2.thumb.png.86a2d81fedf05dde3e74f2056906345b.pngct1.thumb.png.960570f7dafedf423c6cbb6067643cda.png
Make the text smaller so it fits inside the room.
Hi Michael
Thank you for your help. It worked out.
I may bug you in future as well. I am new user of CA and have plenty of questions in my mind.
2 hours ago, solver said:
How are you copying and pasting that Eric?  It looks like you're actually bringing in truly capitalized text somehow whereas my posted text was simply Rich Text formatted to Uppercase.  That being said, and reading back through our back and forth, I can see there some clarification is warranted...
You are correct.  True ALL CAPS does not work.  The macros should be typed in using lower case letters.  Uppercase formatting (what I posted above) should work just fine though.  I'm still curious how you managed to copy and paste my text as actual uppercase letters though.
1 minute ago, Alaskan_Son said:
I'm still curious how you managed to copy and paste my text without the formatting though.
Selected the text in your post, copy, paste into Text Box.
Using a different browser worked.
Video shows what I was doing that was not working.
Interesting.
The browser I use is based on Chrome, and I just tried Chrome and it works the same -- both keep the uppercase.
That seems really weird because it suggests that the browser recognizes the formatting (as evidence by the fact it displays the text as ALL CAPS; however, instead of simply carrying the formatting information, it's actually losing that information and converting the text to capitalized letters.  This behavior is something that typically requires an add-on or extension.
I just your video for Eric...I also get all caps when copying and pasting. No question here, I'm going to search a bit and see if I can find out why.
EDIT:
And there it is...in your edited post way up near the beginning. That was what I suspected.
good to know. I believe that’s the first time I actually posted a pre-formatted macro like that.   I just won’t do it anymore.
    29115
    JasonS92
    JasonS92
