AlmiraDesign
Rafters, birdmouth issue
I am having a difficult time with the framing of the rafters; in regards to birds mouth specifically. I am looking for assistance as I have tried many different options in aligning them to the beams. Please help me! I'd greatly appreciate it!
Ps, I only began to notice the difference, when I changed depth of hip rafters to 3.5".
First...what is the "problem"
Second...please post a plan so we can look at what you are doing.
Thanks!
Chief builds your roof based on your defaults.
If they spec a roof frame of 2x10s, the roof plane is positioned so the 2x10 framing members get a full-seat bearing on your wall framing.  If the wall framing is 2x6, that birdsmouth horizontal dimension will be 5.5 inches.
Your subfascia spec in your roof defaults guide Chief to making the rafter cuts OUTSIDE the wall line.
Play with it a bunch and you'll get it.
The BM is aligned with the Beams but you have the Trim Framing To Soffit Option Set in the Roof Planes so the Rafter Tails are being trimmed Up to the Subfascia Thickness hence the notch on the ends so it appears as if the BM is not Correct.
It looks to me like the issue may be that the birdsmouth for the hip rafter protrudes beyond the support beam at the corner.  It would be great if chief knew how to do this but it may be a while yet before that is an automatic feature. It usually is hidden in the layers or sheathing and siding but is quite apparent if you have a post and beam type structure.
You can apply a custom rafter tail to the hip beams if you need to although I don't think you will get it perfect without doing a laminated beam or building your own with a solid.
Please let us know the exact issue as you have the wiling talent here to get it done even if chief won't do it for you automatically.
    28841
    WKJohnston
    WKJohnston
  • Similar Content
    • By mazakintegrex
      hello,
      I had no idea there was a forum.  this is great!  I have one question for any knowledgeable experts out there!
      is there a way to use auto roof planes & lock all the top heights of the roof ridges so that they all match?  I've been working on my house plan for a few months now & have created manual roof planes to do what I am kind of after, but it is a real pia when a wall needs bumped out or something is revised.  all the rooms are set to the same height, yet it generates roof planes all over the place [height wise].. I've had better results with baseline polyline manipulation, but still left with the same issue.  I want to check a box that says "lock all full gable ridge heights" & let the pitch be the variable.  basically I want full gable ridges 1,2&3 to all be the same height and span the main 3 structures of the house. but when I generate auto roofs, its a mess!
      I also need gable 3 to slope over the porch at a lower pitch and join with gable 1- auto roof bones a hip over porch, if I change the roof group of the octagon nook it gets even wilder!
      rocking with CA premier x12
      thanks in advance!
    • By greglocke
      I have tried every check box I can try and cannot get the birdsmouth on my rafters to lower down onto my beams.  Does anyone have any idea what I'm missing?
    • By RenoByDesign
      When I'm building my roof, I put in a dimension for my roof overhang and it doesn't matter what number I put in the dialog box, it only draws it at 20" deep. What am I doing wrong? I need to fix this so I can draw my roof lines correctly and send out for a roofing quote. I am using Chief Architect Premier X12.
      Thank you, Melissa
    • By Elvis1111
      I am trying to figure out if there is a way to make a framing schedule for the entire project, and not just wall by wall.
      We are finding that framing schedules do a better job listing out the members and sizes then the material lists.
      Thoughts/suggestions?
