amaliya Posted July 1, 2020 Share Posted July 1, 2020 Hi there, Has anyone tried to change the dimensions of the ready floor plan from inches to cm? If so, could you please share with me how? I would really appreciate it! Thank you! Link to comment Share on other sites More sharing options...
rgardner Posted July 1, 2020 Share Posted July 1, 2020 5 hours ago, amaliya said: Hi there, Has anyone tried to change the dimensions of the ready floor plan from inches to cm? If so, could you please share with me how? I would really appreciate it! Thank you! I find the F1 key helps alot in these type of situations. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted July 1, 2020 Share Posted July 1, 2020 8 hours ago, amaliya said: Hi there, Has anyone tried to change the dimensions of the ready floor plan from inches to cm? If so, could you please share with me how? I would really appreciate it! Thank you! You should start the Plan in the Metric Template if you know beforehand you need cm or mm etc. M. Link to comment Share on other sites More sharing options...
joey_martin Posted July 1, 2020 Share Posted July 1, 2020 Just click the dimensions and change them. Select all the dimensions at the same time. There are a couple different ways to do that. 1 Link to comment Share on other sites More sharing options...
amaliya Posted July 2, 2020 Author Share Posted July 2, 2020 When I want it in specific dimension like cm, I change the settings and start the new plan. But I was talking about already an existing plan in iches, to convert them into cm, on the same plan. Link to comment Share on other sites More sharing options...
amaliya Posted July 2, 2020 Author Share Posted July 2, 2020 I did it, thanks! Link to comment Share on other sites More sharing options...
Kiwideziner Posted July 2, 2020 Share Posted July 2, 2020 You should NEVER use cm ion an architectural plan, they are on an ISO standard and could/ probably would cause errors. Only use metres or mm Link to comment Share on other sites More sharing options...
