dshall Posted June 10, 2020 Share Posted June 10, 2020 I see this occasionally and have never taken the time to figure out the cause. Anybody have any ideas? 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted June 10, 2020 Share Posted June 10, 2020 Never seen that. Got a plan? Link to comment Share on other sites More sharing options...
DzinEye Posted June 10, 2020 Share Posted June 10, 2020 That almost looks like an M.C. Escher drawing... Link to comment Share on other sites More sharing options...
Chopsaw Posted June 10, 2020 Share Posted June 10, 2020 It may be a bug or just a funky setting. It seems the stair railing is reading a lowered railing height for the landing and it is making an incorrect transition. Regardless of the situation the balusters should not poke through the railing. Link to comment Share on other sites More sharing options...
robdyck Posted June 10, 2020 Share Posted June 10, 2020 It also appears as though the stair may not be in the correct position butting up to the deck. You can see the stair nosing but it is inside of the deck floor surface. Also, the vector line for the top tread butting up to the deck is missing...another clue as to the top connection. 1 Link to comment Share on other sites More sharing options...
dshall Posted June 10, 2020 Author Share Posted June 10, 2020 22 minutes ago, robdyck said: It also appears as though the stair may not be in the correct position butting up to the deck. You can see the stair nosing but it is inside of the deck floor surface. Also, the vector line for the top tread butting up to the deck is missing...another clue as to the top connection. that may of been it, thx. 1 Link to comment Share on other sites More sharing options...
DzinEye Posted June 10, 2020 Share Posted June 10, 2020 3 hours ago, robdyck said: It also appears as though the stair may not be in the correct position butting up to the deck. You can see the stair nosing but it is inside of the deck floor surface. Also, the vector line for the top tread butting up to the deck is missing...another clue as to the top connection. Good call. Interesting though... pretty sure I've had similar mis-location of stairs before but never had this weird railing issue. Link to comment Share on other sites More sharing options...
robdyck Posted June 11, 2020 Share Posted June 11, 2020 23 hours ago, DzinEye said: Good call. Interesting though... pretty sure I've had similar mis-location of stairs before but never had this weird railing issue. To avoid the railing issue, it helps if you have the rails displayed in plan view and align the handrail of the stairs with the handrail of the deck. Rarely will this mean that the stairs themselves align with the outer edge of the deck. 1 Link to comment Share on other sites More sharing options...
