Subfloor Framing
RDLOGS
I am having a problem that the subfloor framing does not show up in the elevations and 3d shots. It leaves a blank area.
The framing is showing up in the framing overview. Any suggestions.
Thanks
Rickey Donalson
16 hours ago, joey_martin said:
Turn the layer on.
2 hours ago, RDLOGS said:
Tried that already
1 hour ago, RDLOGS said:
yes built subfloor framing and it shows up in the framing overview
Did you check that the layer "Framing, Floor Joists" is indeed on in the views where they're missing, as Joey suggested? By default, chief has that layer turned off in elevation and 3D views.
