jgauntz Posted April 24, 2020 Share Posted April 24, 2020 I have a loft and the flooring for the loft is showing through the wall or is on top of the wall . Is there a setting to stop this from occurring? 3679RivervailDrive_New_FirstFloorplan.plan Link to comment Share on other sites More sharing options...
BryceEngstrom Posted April 24, 2020 Share Posted April 24, 2020 Not exactly sure what you mean, but you have some kind of polyline solid on the first floor that is the concrete material. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 24, 2020 Share Posted April 24, 2020 DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted April 25, 2020 Share Posted April 25, 2020 On 4/24/2020 at 5:42 PM, jgauntz said: I have a loft and the flooring for the loft is showing through the wall or is on top of the wall . Is there a setting to stop this from occurring? 3679RivervailDrive_New_FirstFloorplan.planFetching info... Expand Build it like in the Real World that trimboard sits on the plywood ( subfloor) not on top of the flooring............ Link to comment Share on other sites More sharing options...
DzinEye Posted April 25, 2020 Share Posted April 25, 2020 On 4/25/2020 at 5:00 PM, Kbird1 said: Build it like in the Real World that trimboard sits on the plywood ( subfloor) not on top of the flooring............ Expand If only we could give the bottom rail a negative value for 'raised from floor'... Link to comment Share on other sites More sharing options...
glennw Posted April 25, 2020 Share Posted April 25, 2020 On 4/25/2020 at 5:59 PM, DzinEye said: If only we could give the bottom rail a negative value for 'raised from floor'... Expand There is one trick that may work - depending on the situation. You can't change the bottom height of a rail. So...this is probably easier to do in a cross section view. Select the rail and uncheck Specify Railing - make it a normal wall. Adjust the bottom height to suit. Change it back into a railing. Adjust rail heights, etc. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 26, 2020 Share Posted April 26, 2020 On 4/25/2020 at 5:59 PM, DzinEye said: If only we could give the bottom rail a negative value for 'raised from floor'... Expand The OP wasn't using the Bottom Rail , in fact it could be turned off in this plan, hence my suggestion to just lower the P.Solid to the Real World height. M. Link to comment Share on other sites More sharing options...
DzinEye Posted April 26, 2020 Share Posted April 26, 2020 On 4/26/2020 at 12:43 AM, Kbird1 said: The OP wasn't using the Bottom Rail , in fact it could be turned off in this plan, hence my suggestion to just lower the P.Solid to the Real World height. Expand Yeah, your suggestion was fine, I saw that it was a p-solid, I was just saying if only we could lower the bottom rail then wouldn't have to create a separate p-solid. Link to comment Share on other sites More sharing options...
DzinEye Posted April 26, 2020 Share Posted April 26, 2020 On 4/25/2020 at 11:57 PM, glennw said: Adjust the bottom height to suit. Expand Ah yes.. that might do it. Did you try it? On 4/26/2020 at 12:29 AM, solver said: You can use a ponywall too. Expand True... I just did that recently as a matter of fact. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 26, 2020 Share Posted April 26, 2020 On 4/26/2020 at 2:04 AM, DzinEye said: Ah yes.. that might do it. Did you try it? Expand Yes it works fine , this is the trick to do Fascia Mounted Railing - Search the Topic and you'll find post from me and glenn ...and others about it. M On 4/25/2020 at 11:57 PM, glennw said: There is one trick that may work - depending on the situation. You can't change the bottom height of a rail. So...this is probably easier to do in a cross section view. Select the rail and uncheck Specify Railing - make it a normal wall. Adjust the bottom height to suit. Change it back into a railing. Adjust rail heights, etc. Expand Link to comment Share on other sites More sharing options...
DzinEye Posted April 26, 2020 Share Posted April 26, 2020 On 4/26/2020 at 4:11 AM, Kbird1 said: Yes it works fine , this is the trick to do Fascia Mounted Railing - Search the Topic and you'll find post from me and glenn ...and others about it. Expand Oh...? I thought I saw that post and it required doing a double wall with an invisible inner wall or something like that. I'll have to have another look. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 26, 2020 Share Posted April 26, 2020 On 4/26/2020 at 5:26 PM, DzinEye said: Oh...? I thought I saw that post and it required doing a double wall with an invisible inner wall or something like that. I'll have to have another look. Expand There are two methods , the double wall approach allows for better two post corners etc and was discovered more or less by accident by Doug(?) while trying the method Glenn posted a couple of years ago. Pretty sure I posted sample Plans for others in a couple of those threads for other to look at..... M. Link to comment Share on other sites More sharing options...
