Brenden5 Posted April 18, 2020 Share Posted April 18, 2020 I manually built two gable roofs and joined them at the same roofline. The second roof line isn't fully integrating into the first, as shown in the attached photo the main roofline is fully roofed underneath the existing roof. I am not sure if the original issue of having the two rooflines integrate is causing the fascia and eavestrough to not show up on the exterior or not. I have built attic walls in and effort to close the gaps as well. Any suggestions are appreciated. Premier X11 is being used. Link to comment Share on other sites More sharing options...
Brenden5 Posted April 18, 2020 Author Share Posted April 18, 2020 I have tried but it doesn't produce what I am trying to accomplish. Link to comment Share on other sites More sharing options...
Brenden5 Posted April 19, 2020 Author Share Posted April 19, 2020 I have watched several videos but nothing really speaks to specifically cutting one roof into another. I was just able to get fascia and eaves to show properly along with with manually building the attic walls so they close the gap. Just need to find a way to join the two roofs. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 19, 2020 Share Posted April 19, 2020 Place a break in the main roof and join with the "Join Roof Planes" tool, then once it looks good manually rebuild the roof that remains under the other. Link to comment Share on other sites More sharing options...
DzinEye Posted April 19, 2020 Share Posted April 19, 2020 Sure looks like a pretty straight-forward roof that auto-build should easily do if you set things up right. Before you auto-build the roof simply select the walls where you want a gable to be and open the wall DBX... go to the roof panel and select the box for Full Gable wall... then build the roof. Link to comment Share on other sites More sharing options...
Mark3D Posted April 19, 2020 Share Posted April 19, 2020 try posting your plan, your base line might be off angle not in line with wall Link to comment Share on other sites More sharing options...
BILL88 Posted April 19, 2020 Share Posted April 19, 2020 Agree with above You may not have enough overhang on roof plane. Also make sure your active layer set control is displaying all roof elements. You can use the active set "all on" to see. Link to comment Share on other sites More sharing options...
rgardner Posted April 19, 2020 Share Posted April 19, 2020 By chance did you adjust the shape of those manually drawn attic walls in an elevation view? If you manually edited them you may have pulled them up above the lowest layer of the roof system cutting it off? Hard to tell exactly what the problem is without seeing your plan. Link to comment Share on other sites More sharing options...
Brenden5 Posted April 19, 2020 Author Share Posted April 19, 2020 Thanks for the replies from everyone, I have attached the manual and auto built roofs. As you can see the auto built roof contours the house but I am trying to have a continuous over hang which I don't is optimally achieved using auto build. My manual built is close to being functional if I could get the two roof lines to integrate. Auto Built.plan Manual Built.plan Link to comment Share on other sites More sharing options...
Brenden5 Posted April 21, 2020 Author Share Posted April 21, 2020 On 4/18/2020 at 8:11 PM, solver said: Watch on YouTube: http://youtu.be/RV53TxdYvtc?hd=1 Hi Solver, thanks for taking the time. This worked great. Link to comment Share on other sites More sharing options...
