architekker1 Posted March 31, 2020 Share Posted March 31, 2020 Is there a way to put door swing LH or RH in door label, Text Macro format? Is there a list of Text Macro available to view? Link to comment Share on other sites More sharing options...
robdyck Posted March 31, 2020 Share Posted March 31, 2020 %hinge_side%H Link to comment Share on other sites More sharing options...
architekker1 Posted March 31, 2020 Author Share Posted March 31, 2020 Thank you!!!! Link to comment Share on other sites More sharing options...
robdyck Posted March 31, 2020 Share Posted March 31, 2020 You got it. All I did was use a leader line and the text macro %ObjectProperties% This is already in your system and you can use those properties to your advantage. I can't say too much because I'm no macro guru, but if you try it out, I think you'll see how I got there. Link to comment Share on other sites More sharing options...
JJohnson Posted March 31, 2020 Share Posted March 31, 2020 3 hours ago, architekker1 said: Is there a way to put door swing LH or RH in door label, Text Macro format? Is there a list of Text Macro available to view? Robert, Good one thanks. I left the default label and added the last part of your formula %hinge_side%H only to keep the standard size call out with swing now added Link to comment Share on other sites More sharing options...
robdyck Posted March 31, 2020 Share Posted March 31, 2020 1 hour ago, JJohnson said: Robert, Good one thanks. I left the default label and added the last part of your formula %hinge_side%H only to keep the standard size call out with swing now added What you see in my label shows the width by height in inches because hardly anyone in western Canada knows how to read a standard door / window size, at least not in residential construction. You know how many times I got asked why the doors were 26" x 68"?? Not making that up!! Link to comment Share on other sites More sharing options...
Ridge_Runner Posted April 1, 2020 Share Posted April 1, 2020 1 hour ago, robdyck said: You know how many times I got asked why the doors were 26" x 68"?? Not making that up!! Never understood CA's thinking on that one. Easier to program I guess. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 1, 2020 Share Posted April 1, 2020 I’ve never been a huge fan of the 2668 nomenclature either, and I still find it confusing even when I know it’s happening, but in Chief’s defense, it’s really not uncommon. Plenty of window and door companies call sizes out the same way. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 1, 2020 Share Posted April 1, 2020 By the way, just a side note, but it’s totally possible to do superscript labels in X12 without a custom font. I still prefer a custom font because the superscript numbers are too small with most fonts and look just plain terrible with others, but Chief does fully support Unicode now so all it takes is a pretty simple text macro. Link to comment Share on other sites More sharing options...
DzinEye Posted April 1, 2020 Share Posted April 1, 2020 15 hours ago, Ridge_Runner said: Never understood CA's thinking on that one. Easier to program I guess. 16 hours ago, robdyck said: You know how many times I got asked why the doors were 26" x 68"?? Not making that up!! 14 hours ago, Alaskan_Son said: I’ve never been a huge fan of the 2668 nomenclature either, and I still find it confusing even when I know it’s happening That's been the standard way of calling out sizes since I learned it back in the 80's... is there a different common standard nowadays? Link to comment Share on other sites More sharing options...
Ridge_Runner Posted April 1, 2020 Share Posted April 1, 2020 8 minutes ago, DzinEye said: That's been the standard way of calling out sizes since I learned it back in the 80's... is there a different common standard nowadays? This has been "standard" in my neck of the woods since I can remember. Drafting classes taught it for hand-drawn floor plans and lumber yards/contractors always referred to door sizes this way. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 1, 2020 Share Posted April 1, 2020 11 minutes ago, DzinEye said: That's been the standard way of calling out sizes since I learned it back in the 80's... is there a different common standard nowadays? Same basic naming convention but just written differently using superscript... 2⁶6⁸ or dashes... 2-6 x 6-8 or slashes... 2/6 x 6/8 etc. I know what 2668 means but I still have to expend a lot more mental effort to sort it out in my mind when I read it that way. I prefer the superscript labeling to any other hands down. It's clear and it takes up less space. Link to comment Share on other sites More sharing options...
parkwest Posted April 1, 2020 Share Posted April 1, 2020 Since every 18 or 19 y.o. guy who shows up on the jobsite today is at least a master carpenter... I try to reduce confusion when I can, hence... This is how I like to label openings Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 1, 2020 Share Posted April 1, 2020 8 minutes ago, parkwest said: Since every 18 or 19 y.o. guy who shows up on the jobsite today is at least a master carpenter... I try to reduce confusion when I can, hence... This is how I like to label openings I hope you're using some custom macros for those. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted April 1, 2020 Share Posted April 1, 2020 23 hours ago, architekker1 said: Is there a way to put door swing LH or RH in door label, Text Macro format? Is there a list of Text Macro available to view? Also, keep in mind that what appears to be a left hand door could be a right hand reverse. They are not the same and I'm not sure Chief is smart enough to know the difference. This could be an issue if door edges are beveled or if you are ordering hardware with a key. Link to comment Share on other sites More sharing options...
