LevisL Posted March 26, 2020 Share Posted March 26, 2020 I'm trying to replicate an existing base cabinet in a reno project I'm working on, but I can't figure this one out! It's a 12" wide radius end with open shelves, as this picture shows. In Chief, I can only get a fully open radius end if I make the base cabinet 24" wide. Anything less than 24", the straight edge gets closed off. Any way to get rid of that? I tried making customizing the left side, but that didn't accomplish anything. Link to comment Share on other sites More sharing options...
robdyck Posted March 26, 2020 Share Posted March 26, 2020 Does it work to delete those surfaces, then convert to a symbol? Link to comment Share on other sites More sharing options...
LevisL Posted March 26, 2020 Author Share Posted March 26, 2020 6 minutes ago, robdyck said: Does it work to delete those surfaces, then convert to a symbol? Unfortunately not. I can delete the surfaces and get the look I'm after in the camera view, but when I convert it to a symbol, some of the surfaces show up again... Link to comment Share on other sites More sharing options...
robdyck Posted March 26, 2020 Share Posted March 26, 2020 And if you repeat that process on the new symbol? delete surfaces, convert to symbol again. Link to comment Share on other sites More sharing options...
LevisL Posted March 26, 2020 Author Share Posted March 26, 2020 16 minutes ago, robdyck said: And if you repeat that process on the new symbol? delete surfaces, convert to symbol again. Still no. Deleting surfaces again also deletes some wanted surfaces at the same time. They must join when converting to a symbol. Link to comment Share on other sites More sharing options...
Dermot Posted March 26, 2020 Share Posted March 26, 2020 I think your problem is that you did not delete all of the surfaces you need to. My guess is that you have surfaces facing the other way that don't show up in your normal view but do when you convert it into a symbol. Copy the cabinet into a blank plan and look at it from all angles to find all the surfaces you need to delete. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 26, 2020 Share Posted March 26, 2020 For that scenario you'll not only have to spin that around every which way but you'll also have to use the Alt key to limit which faces you're deleting. Way more time consuming than it's worth. In my opinion, just build from scratch. Link to comment Share on other sites More sharing options...
LevisL Posted March 26, 2020 Author Share Posted March 26, 2020 11 minutes ago, Dermot said: I think your problem is that you did not delete all of the surfaces you need to. My guess is that you have surfaces facing the other way that don't show up in your normal view but do when you convert it into a symbol. Copy the cabinet into a blank plan and look at it from all angles to find all the surfaces you need to delete. I guess you were right. 4 minutes ago, Alaskan_Son said: For that scenario you'll not only have to spin that around every which way but you'll also have to use the Alt key to limit which faces you're deleting. Way more time consuming than it's worth. In my opinion, just build from scratch. That's what I'm finding out. Solves one problem but creates others. I was hoping for a setting in the cabinet dbx that I was missing or something easy like that, but I guess I'll follow Eric's advice after all! Thanks everyone. Link to comment Share on other sites More sharing options...
MarkMc Posted March 26, 2020 Share Posted March 26, 2020 Here is a fixture. If you need in cabinet schedule then needs to be a cabinet door symbol. Started with a shelf... 1 Link to comment Share on other sites More sharing options...
LevisL Posted March 26, 2020 Author Share Posted March 26, 2020 1 minute ago, MarkMc said: Here is a fixture. If you need in cabinet schedule then needs to be a cabinet door symbol. Started with a shelf... radius end cabinet fixture.plan Perfect. Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 26, 2020 Share Posted March 26, 2020 I glanced at Mark's plan and something he had in there made me realize that it actually can be quite a bit quicker to use Delete Surface to create a symbol out of an actual cabinet for this particular scenario. I only ran through it once so the process is a little messy, but you'll get the idea... 1 Link to comment Share on other sites More sharing options...
LevisL Posted March 26, 2020 Author Share Posted March 26, 2020 7 minutes ago, Alaskan_Son said: I glanced at Mark's plan and something he had in there made me realize that it actually can be quite a bit quicker to use Delete Surface to create a symbol out of an actual cabinet for this particular scenario. I only ran through it once so the process is a little messy, but you'll get the idea... Thanks Michael. Some good tips in there! Link to comment Share on other sites More sharing options...
