dshall Posted March 25, 2020 Share Posted March 25, 2020 7 minutes ago, DzinEye said: True, it's not a great solution due to the abruptness of the elevation change, but for speed and a few inches of change I thought it would be acceptable. For a few more seconds I think this solution is more acceptable. I like that solution, that is what I was trying to do with a TERRAIN REGION and it was a mess... not sure what I am doing wrong. 1 Link to comment Share on other sites More sharing options...
Doug_N Posted March 25, 2020 Share Posted March 25, 2020 If you look at my solution there are 3 cross elevation data lines starting at 6" inside the garage, 4" out about 4' from the garage and 0" about 12' out from the garage, There are also 2 elevation lines at the edge of the property at 0" running parallel to the long dimension of the terrain perimeter. The cross-lines are only the pavement width long so they ramp the driveway and leave most of the terrain untouched. It works. Here is a plan file. Garage.plan. Notice the contour lines as well. Link to comment Share on other sites More sharing options...
dshall Posted March 25, 2020 Share Posted March 25, 2020 I used an elevation region and it works fine...... there must be something in my other plan that is not working correctly. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted March 25, 2020 Share Posted March 25, 2020 30 minutes ago, dshall said: I like that solution, that is what I was trying to do with a TERRAIN REGION and it was a mess... not sure what I am doing wrong. In situations like this that is what I normally do too ie place a 6" - 12" wide T.Region across the front of the garage and the rest of the Terrain will slope up to it automatically, haven't tried it in X12 , but are you saying it doesn't work like it used too ? Will give it a try when I have some more time..... *** Edited - I see we posted at the same time.....it does work. M Link to comment Share on other sites More sharing options...
Kbird1 Posted March 25, 2020 Share Posted March 25, 2020 21 minutes ago, dshall said: there must be something in my other plan that is not working correctly If you have overlapping Elevation Data they can definitely mess with each other eg an elevation (contour) line running under the elevation region. M. Link to comment Share on other sites More sharing options...
dshall Posted March 25, 2020 Share Posted March 25, 2020 23 minutes ago, Kbird1 said: .... *** Edited - I see we posted at the same time.....it does work. M it does not work on my mystery plan... the only change was extending the driveway into the garage..... it is the garage that is effecting the terrain.... not sure if I have ever seen this into the garage... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 25, 2020 Share Posted March 25, 2020 On that elevation region, do you possibly have Interior Is Flat unchecked? Link to comment Share on other sites More sharing options...
dshall Posted March 25, 2020 Share Posted March 25, 2020 FYI, a birdie told me what I was doing wrong. I had FLATTEN PAD checked. Uncheck and my TERRAIN ELEVATION behaves. Link to comment Share on other sites More sharing options...
dshall Posted March 25, 2020 Share Posted March 25, 2020 What happens is when it is checked.... the room above will control the terrain elevation. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 25, 2020 Share Posted March 25, 2020 1 hour ago, dshall said: What happens is when it is checked.... the room above will control the terrain elevation. Actually, the room isn't doing anything. What happens when you check Flatten Pad is the exact same thing that would happen if you were to place a Flat Region (Cut/Fill) shaped exactly like your exterior room perimeter on the lot. Chief just modifies the terrain to essentially create a flat spot on the desired footprint without adding or removing any material from that area. It might dip down to make this happen (cut) or it might rise up (fill)... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 25, 2020 Share Posted March 25, 2020 Here's how those Flat Regions work... ...and Flatten pad does the exact same thing. Link to comment Share on other sites More sharing options...
DzinEye Posted March 25, 2020 Share Posted March 25, 2020 1 hour ago, Alaskan_Son said: Here's how those Flat Regions work... Very cool demo!... thank you. Link to comment Share on other sites More sharing options...
