Hammer7 Posted March 16, 2020 Share Posted March 16, 2020 Good morning, My design sheet is 24 x 36 and all is good but when I want to send that to print on an 11 x 17 paper is there a way to do this and have the dimensions print larger? I'm looking for video or reference set to this and I am running x 12 now. Link to comment Share on other sites More sharing options...
robdyck Posted March 16, 2020 Share Posted March 16, 2020 You need a separate default set to change scales. Let's say your currently setup for 1/4" scale and want to use 1/8" scale. Copy the default set that you use for 1/4" scale, rename it and double the size of the text, dimension text, arrows, etc. Also a good idea to have 2 separate saved plan views for each scale, named so that you know which is which, of course! Link to comment Share on other sites More sharing options...
robdyck Posted March 16, 2020 Share Posted March 16, 2020 For dimensions, marquee select all of them, copy them, change their default and layer! Link to comment Share on other sites More sharing options...
Hammer7 Posted May 5, 2024 Author Share Posted May 5, 2024 I'm revisiting this because last time I came up with a solution for a work around but this has come up again and I am finding others who have had this problem too. I tried to follow Rob's suggestions above but I think I need some interim steps to correct defaults or views. My dimensions are large in plan view but too small in layout. I will post the current settings in plan view too. Link to comment Share on other sites More sharing options...
Hammer7 Posted May 5, 2024 Author Share Posted May 5, 2024 Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 5, 2024 Share Posted May 5, 2024 What is in your text style Link to comment Share on other sites More sharing options...
Gawdzira Posted May 5, 2024 Share Posted May 5, 2024 The Plot Plan Default set (out of the box) with X15 Since I most often send my Plot Plan (renamed Site Plan) at 1/8" scale, I have my text set to 12" and my arrows set to 7" (they are the "Slash" type). These are my 1/8" scale drawing defaults. Check your minimum display size in Preferences. That might be what is making your plan views look like you have massive dimensions Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 5, 2024 Share Posted May 5, 2024 On 3/16/2020 at 9:38 AM, Hammer7 said: My design sheet is 24 x 36 and all is good but when I want to send that to print on an 11 x 17 paper is there a way to do this The simplest way is to print at 1/2 scale. In the Print View dialogue box. > Drawing Scale > Check Plot at “1/2 Scale” Since 11x17 is roughly half of 24 x 36 you might only need some minor tweaking of objects too close to the edge. Adjust those and you’re all good. Be aware that your scale reference which was probably set at 1/4” in now effectively 1/8” once printed. You might want to change that on your plans as well. Link to comment Share on other sites More sharing options...
