decorators3 Posted February 15, 2020 Share Posted February 15, 2020 Hi I'm having trouble creating a corner unit for wall oven ..I have tried building a corner wall unit.. but appliances cant be inserted into a corner. Any suggestions. attached is the unit i'm trying to recreate in my design Thanks Levina Link to comment Share on other sites More sharing options...
joey_martin Posted February 15, 2020 Share Posted February 15, 2020 That's just a regular full height cabinet turned 45 degrees. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 15, 2020 Share Posted February 15, 2020 20 minutes ago, joey_martin said: That's just a regular full height cabinet turned 45 degrees. I think Joey is right , stadard cabinets with a couple of Partitions like : Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 15, 2020 Share Posted February 15, 2020 Although I agree with the guys above, you can use a corner cabinet as well. You have to insert the appliance as a face item through the dialog (it just can't be dragged and dropped form library is all)... ...problem is that the CAD block displayed in plan view is all wrong. My personal approach is to almost always just leave the appliance area blank (like it will be in real life), size the opening appropriately (so the cabinet is correct), place the appliance in the plan as a a standalone item, size the appliance appropriately (so the appliance is correct), and then position the appliance manually in the cabinet. 1 Link to comment Share on other sites More sharing options...
MarkMc Posted February 15, 2020 Share Posted February 15, 2020 Yes regular cabinet BUT if adjacent to cabinets with doors you need a "zero filler" or whatever the maker calls it (if they offer one). OR a filler to create a larger gap. Just placed on an angle reveals as narrow as shown the doors won't work. Check with supplier Link to comment Share on other sites More sharing options...
