Mullion between double door
kwhitt
Is it possible to place a mullion between a pair of double doors?  I need the width of the mullion to accurately depict the overall width of the opening.  I thought there might be an option/setting I was overlooking.  Thanks.
  On 2/4/2020 at 2:35 PM, Joe_Carrick said:
Is that really a mullion or is it an astragal?  Chief doesn't include the astragal on a double door.  It's a 3D detail that just isn't included.
Expand
It's definitely an astragal, but doubling the jamb is close enough and as Ryan mentioned, I could always place a vertical molding.  Thanks again for the tip on using two doors.
Expand
The problem with that is that you get the appearance of just a narrow casing both inside and outside.  It's not the same as a double door.  But it you're just looking for the appearance in a rendering...…..
