KilianDrafting Posted January 7, 2020 Share Posted January 7, 2020 Is there a any way to create an arched window like this? The center unit is no problem, but I can't seem to get the units on each side to have an "inverted" arch. Arch Window.pdf Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 7, 2020 Share Posted January 7, 2020 Custom symbol. Link to comment Share on other sites More sharing options...
DzinEye Posted January 7, 2020 Share Posted January 7, 2020 2 hours ago, KilianDrafting said: Is there a any way to create an arched window like this? The center unit is no problem, but I can't seem to get the units on each side to have an "inverted" arch. Pssh... even a proper non-inverted 3-part broken arch is impossible with current window tools. I can only get them about as shown... looks terrible to me 1 Link to comment Share on other sites More sharing options...
joey_martin Posted January 7, 2020 Share Posted January 7, 2020 Mull the windows together THEN set the arch. 2 Link to comment Share on other sites More sharing options...
DzinEye Posted January 7, 2020 Share Posted January 7, 2020 9 minutes ago, joey_martin said: Mull the windows together THEN set the arch. 9 minutes ago, solver said: Place your 3 windows with flat tops. Mull them. Set the arch. OMG!.. thanks guys. I tried so many things and the idea of mulling then arching did not occur to me. Much appreciated. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 7, 2020 Share Posted January 7, 2020 ...or, if you don't actually want them mulled... Link to comment Share on other sites More sharing options...
DzinEye Posted January 7, 2020 Share Posted January 7, 2020 21 minutes ago, Alaskan_Son said: ...or, if you don't actually want them mulled... Thank you Michael, Aaaarghh... If I had tried using 'Double arch' instead of 'Broken arch' I could have got it to work. In a way I'm glad I didn't figure it out though, because then I wouldn't have complained and learned the mulling trick...LOL. Mulling is certainly the easier way to go. However, there may come a case where it's not, so good to know this double arch method. Appreciate the well-made video. Link to comment Share on other sites More sharing options...
SNestor Posted January 7, 2020 Share Posted January 7, 2020 57 minutes ago, joey_martin said: Mull the windows together THEN set the arch. Joey knows what he's talking about. This method makes it "easy-peasy".... Link to comment Share on other sites More sharing options...
DzinEye Posted January 8, 2020 Share Posted January 8, 2020 On 1/7/2020 at 8:32 AM, KilianDrafting said: Is there a any way to create an arched window like this? The center unit is no problem, but I can't seem to get the units on each side to have an "inverted" arch. Rich, In the 'Suggestions' part of the Forum, suggest that Chief implement the ability to input negative radius values for a 'double arch' so the inverted arch could be done. 1 Link to comment Share on other sites More sharing options...
