KatherineD Posted December 12, 2019 Share Posted December 12, 2019 Hi New to CA. How do I alter my settings to be able to type in my interior dimension that I desire, rather than the exterior one? Link to comment Share on other sites More sharing options...
GeneDavis Posted December 12, 2019 Share Posted December 12, 2019 Here is two room house I quickly sketched. I selected the interior wall. Look at the picture. And fill out your signature (if you are a Chief Premium user) so we know. If using Home Designer or something else, find the appropriate forum to post your question. Link to comment Share on other sites More sharing options...
javatom Posted December 12, 2019 Share Posted December 12, 2019 You can also set the defaults for the dimensions to see both wall sides (or what ever you want it to see). Link to comment Share on other sites More sharing options...
robdyck Posted December 12, 2019 Share Posted December 12, 2019 2 hours ago, KatherineD said: Hi New to CA. How do I alter my settings to be able to type in my interior dimension that I desire, rather than the exterior one? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 13, 2019 Share Posted December 13, 2019 7 hours ago, KatherineD said: Hi New to CA. How do I alter my settings to be able to type in my interior dimension that I desire, rather than the exterior one? If doing Remodel Work and measuring existing Homes to wall Surfaces eg Drywall , not Framing you can set your Dimension defaults to locate Surfaces instead of the Wall Dimension Layer (Framing Layer usually). In the General Wall Defaults (Alt-Q) you could also switch the Resize about Option to Main Layer Inside (Framing) or Inner Surface temporarily while laying out walls. Link to comment Share on other sites More sharing options...
