ChiefuserDRB 0 Posted November 20, 2019 Has anyone had issues changing exterior wall materials? I am confused as to why some of my walls will not change from the default blue siding when adjacent and connecting walls have no issues. Share this post Link to post Share on other sites
SNestor 474 Posted November 20, 2019 7 minutes ago, ChiefuserDRB said: Has anyone had issues changing exterior wall materials? I am confused as to why some of my walls will not change from the default blue siding when adjacent and connecting walls have no issues. Have you used the "spray can" to "paint" the walls? If so...you will have to open the wall dialogue box...and go to the materials tab...select "exterior wall surface"...then click the "select material" button...then, make sure you have "library materials" selected...and at the bottom you will see a check box, "use default material". Check this box... The wall should return to the siding you set as the default material. This is occurs when you "paint" a material instead of opening the wall and modifying the "wall type". Share this post Link to post Share on other sites
Joe_Carrick 2313 Posted November 20, 2019 The best method is to actually create a wall type or edit the existing. Using the "Spray Can" is just not a good idea for walls. 1 2 Share this post Link to post Share on other sites
Kbird1 814 Posted November 21, 2019 8 hours ago, SNestor said: Have you used the "spray can" to "paint" the walls? If so...you will have to open the wall dialogue box...and go to the materials tab...select "exterior wall surface"...then click the "select material" button...then, make sure you have "library materials" selected...and at the bottom you will see a check box, "use default material". Check this box... The wall should return to the siding you set as the default material. This is occurs when you "paint" a material instead of opening the wall and modifying the "wall type". You can also scroll to the top of the Plan Materials list and chose Use Default too. And yes don't spraycan exterior Walls .... it will comeback to haunt you..... M. 1 Share this post Link to post Share on other sites
Alaskan_Son 2458 Posted November 21, 2019 18 hours ago, Joe_Carrick said: Using the "Spray Can" is just not a good idea for walls. 10 hours ago, Kbird1 said: And yes don't spraycan exterior Walls .... it will comeback to haunt you..... I teach people to avoid painting walls for the most part too. Usually best to change the wall definition or add a material region. BUT, I do stop short of saying not to do it altogether It has its place in my opinion. It's just not very common. Share this post Link to post Share on other sites
