Contour lines & building elevations - normally included in topo survey ?
jplee123
Hello. Are contour lines and building (floor, roof) elevation data normally included in a topographical survey? I had expected this from my topo + boundary survey, but the surveyor does not appear to have provided these details in my survey deliverables (attached).
I created the .plan from the .dwg, having imported all details using Home Designer Pro 2020). Did I do the import incorrectly?
The vendor has become non-responsive. In case I'm unable to settle this via simple/friendly means, how would I submit and settle a dispute about this?
Here is the text of the agreement, which doesn't specify one way or the other that contour lines & building elevations will be included, so I believe I'm left with standard & traditional service definitions of a Topographical survey.
2 additional pages of the agreement include only standard legal-ese (e.g. arbitration agreement), not any further definitions of services. All service descriptions are referenced back to the proposal shown above.
As always, thank you!
Jay.
Topo-217ValleVistaAve.dwg
Topo-217ValleVistaAve.zip
Survey217ValleVistaAveModel.pdf
Roof and floor elevations would be optional information, as would utility information. (see: http://content.aia.org/sites/default/files/2016-09/AIA-C201-2015-Free-Sample-Preview.pdf ) There are many levels of information possible in a survey, and it appears you have received a "basic" survey, which even includes information on adjacent property, and which is usually optional. So, while you may have been hoping for more, I don't see that the surveyor provided less than requested. On a flat lot such as this, since contour lines are usually at even foot intervals (and often at two, five, or ten-foot intervals), you might have one contour line max, which would be kind of silly.
When you are spending that amount of money it is up to you to make sure there is a clear understanding of the work that is to be done.
Also it is often a good idea to be on site when the work is being done as there can be communication breakdowns with employees.  It is a lot simpler to just make sure everything has been measured before they pack up their tools than it would be to have them come back to the site a second time.
From your PDF it appears that they did do the work that would normally be required.
Looks about right to me too, Roof wouldn't be normal in a Topo Survey, though the Surveyor has not labelled the 1st Floor Floor Height nicely for you on the PDF which they normally do around here. ( bottom of front Door sill for example) but in your case I think they might be the 676.01 ( front door) and 676.14 heights ( back door )
your Plan file is empty (zip) which usually means you zipped it while the plan was open in Chief / HD Pro.
