Railing/Wall Intersections
MTL-Homes
Anybody have any idea whats going on with the intersections of these deck railings and the exterior walls? Cant get the original default siding to go away at the intersection. Have tried editing default material and making adjustments with the wall layer extents tool.
29 minutes ago, Designer1 said:
This very problem happens to me nearly every time, so annoying.  Regardless of plan it happens.  I'm so interested what the solutions to this issue will be.
If you are good at reproducing that issue I am sure one of the pros could figure out what is going on if you post a sample plan file.
Good idea.  I just thought this was normal since it happens so much. For me I just accepted it as the way chief behaves with different wall types, I see this in bathroom design a lot with glass walls or walls with different thickness.
