kwhitt Posted September 18, 2019 Share Posted September 18, 2019 I've looked on the internet and forum and can't find an answer to this. Does CA have a breakline symbol that generates automatically like it does for stairs or do I have to do it manually? I used this all the time in AutoCAD, but can't find an equivalent in CA. Thanks. Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 18, 2019 Share Posted September 18, 2019 2 minutes ago, kwhitt said: I've looked on the internet and forum and can't find an answer to this. Does CA have a breakline symbol that generates automatically like it does for stairs or do I have to do it manually? I used this all the time in AutoCAD, but can't find an equivalent in CA. Thanks. I made this a while ago, though I use a different style now: 2 Link to comment Share on other sites More sharing options...
rlackore Posted September 18, 2019 Share Posted September 18, 2019 Manual only AFAIK. A proper breakline in Chief is so tedious that I now just use a heavy dashed line: 1 2 Link to comment Share on other sites More sharing options...
kwhitt Posted September 18, 2019 Author Share Posted September 18, 2019 Thanks Renee. That will work for future situations, but I need a single break for now. Link to comment Share on other sites More sharing options...
kwhitt Posted September 18, 2019 Author Share Posted September 18, 2019 rlackore - you're right. It is tedious. I'm sticking with the dashed line. Does CA have an overkill tool like AutoCAD to remove overlapping segments in a CAD detail view? Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 18, 2019 Share Posted September 18, 2019 6 minutes ago, kwhitt said: Thanks Renee. That will work for future situations, but I need a single break for now. Just unblock it and delete the second line, then re-block and add to library...then add a library symbol to your toolbars and you can access it with one click Link to comment Share on other sites More sharing options...
kwhitt Posted September 18, 2019 Author Share Posted September 18, 2019 1 minute ago, Renerabbitt said: Just unblock it and delete the second line, then re-block and add to library...then add a library symbol to your toolbars and you can access it with one click You're right. Thanks! 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 18, 2019 Share Posted September 18, 2019 There are breakline symbols in the Core Library. You can place them and if you want, you can use them to trim other objects. 1 1 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 18, 2019 Share Posted September 18, 2019 Not 100% sure what you are asking without a pic, but I think a CAD mask would work; white lines & white, solid fill - works for printing in B&W just fine and should work for color in may cases. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 18, 2019 Share Posted September 18, 2019 5 minutes ago, Ridge_Runner said: Not 100% sure what you are asking without a pic, but I think a CAD mask would work; white lines & white, solid fill - works for printing in B&W just fine and should work for color in may cases. Don’t forget that we have an invisible line style too...which is what I typically use. I almost never (IF ever) use white line for anything. 1 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 18, 2019 Share Posted September 18, 2019 1 minute ago, Alaskan_Son said: Don’t forget that we have an invisible line style too...which is what I typically use. I almost typed that in but didn't for some unknown reason. Link to comment Share on other sites More sharing options...
kwhitt Posted September 18, 2019 Author Share Posted September 18, 2019 Thanks all for the suggestions. Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 18, 2019 Share Posted September 18, 2019 2 hours ago, Joe_Carrick said: There are breakline symbols in the Core Library. You can place them and if you want, you can use them to trim other objects. If only the trim function would retain fill at the break line/fence Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 18, 2019 Share Posted September 18, 2019 38 minutes ago, Renerabbitt said: If only the trim function would retain fill at the break line/fence https://chieftalk.chiefarchitect.com/topic/18681-allow-open-polylines-to-be-used-for-polyline-subtraction-operations/?tab=comments#comment-154134 Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 18, 2019 Share Posted September 18, 2019 1 minute ago, Alaskan_Son said: https://chieftalk.chiefarchitect.com/topic/18681-allow-open-polylines-to-be-used-for-polyline-subtraction-operations/?tab=comments#comment-154134 plus-ed it Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 18, 2019 Share Posted September 18, 2019 2 minutes ago, Renerabbitt said: plus-ed it same Link to comment Share on other sites More sharing options...
brubaker Posted March 15, 2024 Share Posted March 15, 2024 I made this and it works pretty well. Add it and scale to the size you need. Break Line.calibz Link to comment Share on other sites More sharing options...
