Add to Library vs. Add to Library as Stacked Molding
Can someone tell me what the difference is here?  Are there pros/cons to each?  I am creating a light rail molding that will require a face profile and a return allowing the installer to attach to the bottom of wall cabinets (2 piece molding).  It appears I can add to Library either way, but in this instance which is the preferred method?  Technically it is a stacked molding.  Thanks!
3 minutes ago, Alaskan_Son said:
Just try it and you’ll quickly see the difference.
I almost said that:)
As noted in other thread understand how the program sees things, which means try anything / everything with an eye to that not just to where you want to go. Along those lines I use the reference manual constantly.
Great answer Mark. Trial and error is a great teacher.
    29613
    Pav-Arch
    Pav-Arch
