DianeP Posted September 3, 2019 Share Posted September 3, 2019 How can I get the wall color to show up when it prints. It used to do it but I must have turned something off on the layout page and can't find how to turn it back on now. Thanks folks!! Link to comment Share on other sites More sharing options...
DG1949 Posted September 3, 2019 Share Posted September 3, 2019 With the Layout sheet open, in the main menu. go to View>Color. Make sure it's checked. Also "F8" keystroke should work. 2 Link to comment Share on other sites More sharing options...
Kenoeightspot Posted September 3, 2019 Share Posted September 3, 2019 Check color box 2 Link to comment Share on other sites More sharing options...
DianeP Posted September 3, 2019 Author Share Posted September 3, 2019 Thanks for trying to help. I wasn't clear. The color is viewable on the layout page but it won't print with the shading that is there on the floor plan view. It just gives the wall lines with out the shading. Sometimes I want it to have the shading showing when it is printed. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 3, 2019 Share Posted September 3, 2019 try color off is grayscale in preferences, then print in color with you print drivers. If you turn off color using the color off button you will see what it looks like. Just make sure yuou keep colors on the dark side so they show up . light gray doesn't work. 1 Link to comment Share on other sites More sharing options...
DianeP Posted September 3, 2019 Author Share Posted September 3, 2019 13 minutes ago, DRAWZILLA said: try color off is grayscale in preferences, then print in color with you print drivers. If you turn off color using the color off button you will see what it looks like. Just make sure yuou keep colors on the dark side so they show up . light gray doesn't work. Perfect! Just what I wanted and couldn't remember how to do. Thanks!!!! 1 Link to comment Share on other sites More sharing options...
