    29477
    heatherfox
    heatherfox
  • Similar Content
    • By Doug-ib
      First post here, this is my first attempt at roof truss. As you will see in the PDF attached the gables that are on the front of the duplex are being supported by the truss that are running in the vertical direction. I am wondering if this is normal as i cannot seem to create truss for the gables on the font of the home. If there is a more effective means of building roof truss for roofs of this style id love to hear them.
      truss question.pdf front view.pdf
    • By since1937
      How can I enclose the roof overhang so the beams/trusses aren’t exposed when walking outside from French doors? In the picture I colored in red where I’m trying to not have an open overhang. The overhang is 8’, and I will have structural posts to hold up overhang.
    • By aurorainteriors
      Hi All.
      Still new to the program and figuring things out. I have built an automatic roof and am trying to modify it to be a gable roof instead of the default hip roof. I have watched the various videos on how to do this as well as read through forums and have not been able to figure out why my roof will not adjust to a gable after changing each wall to be a gable setting. I've attached screenshots and uploaded the file. The client only wanted a model for purposes of seeing a new deck/stair option and paint color so the roof isn't the most important thing but I still want it to resemble their house.
      Thanks,
      Krissy
      Chief Architect Premier X12 (64 bit)
      Bristol House.plan
    • By ericepv
      Rochester, NY based rendering company available for remote work. I am a long time Chief user (currently on X-12 but equipped with earlier versions also) and have worked for many commercial and residential clients across the country. You can view samples of my work on my website https://epvisualz.com .
      Please contact me directly at 585-441-5291 EST or by email: eric@epvisualz.com .
    • By DJohnsonSC
      I am trying to create a story and a half main house that has a two story gable roof addition.  I have been able to create the story and a half with a 1 story addition but can't figure out how to add a second story to the addition.  The main part of the house has a 10/12 roof (created by build roof options: move roof up 12', ignore 2nd floor).  The goal is to have the main roof 10/12 and the 2 story addition a 6/12 gable.
      Pics below are a quick mockup. One showing the successful story and a half w addition.  The other a bit more unusual configuration that I may not be able to get past the building inspector.
      Thanks in advance for any help provided.
