mikes616 Posted July 25, 2019 Share Posted July 25, 2019 Is there an easy way to create deck newel posts manually? It seems like you can only modify spacing, size and what is available in the library- all automatically. If I want a different newel spacing, or a different newel design what can I do? The deck is roofed over. Chief 11 user. Thanks. Mark Link to comment Share on other sites More sharing options...
mikes616 Posted July 25, 2019 Author Share Posted July 25, 2019 I'm trying to place the newels ( columns) in specific locations. I want to use my own dimensions, not Chief's "spacing". Mark Link to comment Share on other sites More sharing options...
mikes616 Posted July 25, 2019 Author Share Posted July 25, 2019 That works, thanks. Link to comment Share on other sites More sharing options...
SNestor Posted July 25, 2019 Share Posted July 25, 2019 1 hour ago, mikes616 said: Is there an easy way to create deck newel posts manually? It seems like you can only modify spacing, size and what is available in the library- all automatically. If I want a different newel spacing, or a different newel design what can I do? The deck is roofed over. Chief 11 user. Thanks. Mark I’ve got a few deck videos on my YouTube page you might find interesting... Link to comment Share on other sites More sharing options...
dshall Posted July 25, 2019 Share Posted July 25, 2019 2 hours ago, mikes616 said: Is there an easy way to create deck newel posts manually? It seems like you can only modify spacing, size and what is available in the library- all automatically. If I want a different newel spacing, or a different newel design what can I do? The deck is roofed over. Chief 11 user. Thanks. Mark Every time I think about doing railings auto, I feel I do not have enough control. So I use individual. newel posts and a molding pline for the railing. I find it easier, quicker and I have more control. I put a quick plan together you can look at..,. Untitled 6 railing 6.planUntitled 6 railing 6.plan 2 Link to comment Share on other sites More sharing options...
mikes616 Posted July 25, 2019 Author Share Posted July 25, 2019 Thanks, Steve & Scott. Very helpful. Mark Link to comment Share on other sites More sharing options...
mikes616 Posted July 25, 2019 Author Share Posted July 25, 2019 Scott, Just need to clarify...do you place your newels yourself per your dimensions and then add your railings between them? It appears that your railings go through the newels and posts. Is that correct? Also, how do you make the space identify as a "room"? Thanks. Mark Link to comment Share on other sites More sharing options...
SNestor Posted July 26, 2019 Share Posted July 26, 2019 7 hours ago, dshall said: Every time I think about doing railings auto, I feel I do not have enough control. So I use individual. newel posts and a molding pline for the railing. I find it easier, quicker and I have more control. I put a quick plan together you can look at..,. Untitled 6 railing 6.planUntitled 6 railing 6.plan Scott...love this molding idea for the pickets. I would make one modification to the picket symbol...I'd make the top piece something like 1/4" or 1/2" thick x 2" wide (or same width as picket)...then, you can bury this "connector" piece of the symbol in the bottom surface of the top rail. Then...in Vector View you won't see the molding repeat lines. Just an option to an otherwise fantastic idea for railings. 1 Link to comment Share on other sites More sharing options...
dshall Posted July 26, 2019 Share Posted July 26, 2019 9 hours ago, SNestor said: Scott...love this molding idea for the pickets. I would make one modification to the picket symbol...I'd make the top piece something like 1/4" or 1/2" thick x 2" wide (or same width as picket)...then, you can bury this "connector" piece of the symbol in the bottom surface of the top rail. Then...in Vector View you won't see the molding repeat lines. Just an option to an otherwise fantastic idea for railings. I usually do bury it, this was down and dirty. 1 Link to comment Share on other sites More sharing options...
dshall Posted July 26, 2019 Share Posted July 26, 2019 11 hours ago, mikes616 said: Scott, Just need to clarify...do you place your newels yourself per your dimensions and then add your railings between them? It appears that your railings go through the newels and posts. Is that correct? Also, how do you make the space identify as a "room"? Thanks. Mark I place jewels, railing is continuous, invisible walls to define room. 1 Link to comment Share on other sites More sharing options...
tommy1 Posted July 26, 2019 Share Posted July 26, 2019 If I'm understanding Scott right, I think I work similar to him. Most of the time, I also place my columns manually. This makes it easier for me to dimension beam spans for the engineer. I've been doing it like this for so many years that it really doesn't take long to do it. Link to comment Share on other sites More sharing options...
MarkMc Posted July 26, 2019 Share Posted July 26, 2019 3 hours ago, dshall said: I place jewels... 2 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted July 26, 2019 Share Posted July 26, 2019 Too funny... Link to comment Share on other sites More sharing options...
mikes616 Posted July 27, 2019 Author Share Posted July 27, 2019 Thanks for all the help everyone. Mark Link to comment Share on other sites More sharing options...
