Custom Object Field
stephenbc
Is it possible to put a custom object field into a label, for say a window?  Can't seem to find any documentation on this.  I created a custom object field, but don't understand how to get that into a label, in a way similar to simply inputting a macro in a label.  Please note, that I'm rather weak on understanding the use of macros.  Thanks.
1 hour ago, solver said:
See if this helps.
Ha! It absolutely does.  Thanks Solver.  I wondered how the "custom_fields" syntax and set up worked...and with two pictures, you've explained it.
Now, at least, when I change a window or add another window, my updated window schedule won't reorder all the windows!
  • 3 months later...
15 minutes ago, Evolution said:
Thanks Yoda! I used the wrong search word missed this help!
Just a quick tip, but don't limit yourself to simply searching the Help files.  You can also:
  • Click the Help button in any one of the dialog boxes and it will typically take you straight to the section regarding that specific dialog.
  • Click Help with an object selected and it will typically take you straight to the most relevant section on EDITING that particular object type.
  • Click Help with only a tool activated and it will typically take you straight to the most relevant section on USING that particular tool.
Help is by far the most underutilized resource at our disposal IMO.
Thanks Michael. This is stuff "I should know" and hopefully the more I get to use the software, (I might likely retain some of this great information)! It isn't because I don't study, watch the video's and search the KB...…..my wife will vouch for that.
    30205
    emmabrownnn
    emmabrownnn
