Advice on multi story house
10eighty
So I have this house I'm working on that should have been a straight forward 2 story with daylight basement.  But for some reason, they want to put a crawl space under the "basement" floor. It's on a slope, and I personally would have just built it into the foundation.  So here is the situation.... I changed the foundation floor plan to floor 1, the 1st floor to floor 2, and the bonus room over the garage to floor 3.  Then I built a new basement under floor 1 with standard foundation heights.  Then changed floor 1 walls to 8" concrete walls for the retained underground walls.  The weird part is that the garage is technically floor 2 and I have nothing on floor 1 for the garage, and the foundation for the garage is on the foundation level. So I changed the heights the best I could to bring the foundation up, but I'm not getting cutouts for the garage doors.  Is there a better way to address this situation? oh, and I attached the x9 plan file, its pretty haggard but it should open lol
Thanks in advance,
Randy
Foundation.pdf
Floor 1.pdf
Floor 2.pdf
Floor 3.pdf
Eagle View Terrace.plan
Yes, technically the front of floor 1 is underground, and floor 2 (the main level) has the garage.  But it seems by doing it this way nothing seems to connect floor 0 and floor 2 as far as the garage goes.  I just raised the floor 0 elevation to meet the floor 2 garage.  Sorry, I'm having a difficult time trying to explain my concern. Is this how you would handle this circumstance? In other words, Floor 0 to carry the garage foundation Floor 1 for the daylight part of the house no garage, and then Floor 2 for the garage. Sorry in advance lol
there are two schools for approach
1. combine foundation and basement on floor 0
    this has been the "traditional" method from CA since the beginning
2. others dedicate floor 0 to the foundation and floor1 to the basement and floor 2 to the main level
either approach is appropriate
I'm guessing - as this is NOT my forte - by maybe the garage should be on floor 0
so it connects to the foundation on floor 0, while the basement on floor 1 also connects to the foundation
then floor 2 sits on the basement ?
place terrain on floor 1 then adjust as needed ?
Lew
