EconBlueprints Posted May 10, 2019 Share Posted May 10, 2019 I have a plan that requires a bearing wall in the basement. No problem, draw wall, specify foundation wall, and there it is. But, the footings for this wall do not extend beyond the ends of the wall, and neither end of this wall is connected to an outside wall. The footings show up as actually being short of the wood frame bearing wall above. Is there any way to manually adjust the ends of the footings so they go beyond the ends of the walls above? Thanks, Lane Link to comment Share on other sites More sharing options...
rlackore Posted May 10, 2019 Share Posted May 10, 2019 It works fine for me: ...and it should, according to the Reference Manual: Link to comment Share on other sites More sharing options...
EconBlueprints Posted May 10, 2019 Author Share Posted May 10, 2019 Got it, thanks. I drew a wood partition wall, then changed it to a foundation wall. No good. I drew a foundation wall, and changed the wall type to wood wall. Good. Link to comment Share on other sites More sharing options...
SNestor Posted May 10, 2019 Share Posted May 10, 2019 3 hours ago, EconBlueprints said: Got it, thanks. I drew a wood partition wall, then changed it to a foundation wall. No good. I drew a foundation wall, and changed the wall type to wood wall. Good. Well...I just learned something I never knew. Thanks. Link to comment Share on other sites More sharing options...
robdyck Posted May 10, 2019 Share Posted May 10, 2019 In the walls dbx, General Tab, check "foundation wall". Structure Tab, check "bearing wall" 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 10, 2019 Share Posted May 10, 2019 For these situations, which is often the case for interior support walls, I use p-solids for footings that way I can control them. Deselect footing and add your own footings. It's easier. I've even built an entire floor that contained only footings. Basically putting footings on its own floor. Link to comment Share on other sites More sharing options...
misterwiley Posted May 11, 2019 Share Posted May 11, 2019 20 hours ago, Michael_Gia said: For these situations, which is often the case for interior support walls, I use p-solids for footings that way I can control them. Deselect footing and add your own footings. It's easier. I've even built an entire floor that contained only footings. Basically putting footings on its own floor. How do you handle stepped footings in this case? Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 11, 2019 Share Posted May 11, 2019 7 hours ago, misterwiley said: How do you handle stepped footings in this case? For stepped footings I draw the p-solid in an elevation view and set the depth. Drawing in elevation I can use a standard polyline and trace out the step. Then convert polyline to p-solid and set the depth. Go back to plan view and place it where I need it. Usually centring it on a foundation wall. Then I go back into elevation view, add breaks to my wall and drag the wall bottom to snap to my p-solid stepped foundation. Of course you can step a foundation wall with footings the same way just that you loose control of the independent shaping and visibility of your footing. Here is the master, Scott Harris from Chief showing that method: https://www.chiefarchitect.com/videos/watch/6185/foundations-for-extreme-slopes-lake-point-project.html Link to comment Share on other sites More sharing options...
