Fotis1960 Posted March 26, 2019 Share Posted March 26, 2019 Does any one have a macro for Room Perimeter? I'm not a professional CA user. I use it for small home projects and for fun so I haven't learned how to create my own macros yet. Any assistance would be appreciated. Thank you Link to comment Share on other sites More sharing options...
Kbird1 Posted March 26, 2019 Share Posted March 26, 2019 12 minutes ago, Fotis1960 said: Does any one have a macro for Room Perimeter? I'm not a professional CA user. I use it for small home projects and for fun so I haven't learned how to create my own macros yet. Any assistance would be appreciated. Thank you What Info are you looking for? as CA has built in Marcos for the basics like Area and Perimeter etc M. Link to comment Share on other sites More sharing options...
Fotis1960 Posted March 26, 2019 Author Share Posted March 26, 2019 I wanted a fast way to get the total feet of base molding needed for a room. I realized that I could get it from the materials list after I posted the question but would still like to have a room perimeter macro. I couldn't find one for perimeter in the CA provided ones. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 26, 2019 Share Posted March 26, 2019 - If you click on the Room, you can make a Room Polyline (edit toolbar) and it has a total length etc in the DBX..... - you can also Place a Room Finish Schedule in a CAD Detail (best) and use the available Columns to document thinks like Moldings. M. Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 27, 2019 Share Posted March 27, 2019 If you select the room and make a room polyline as mentioned before you can insert the %perimeter% in the label tab of the polyline dialogue box. Link to comment Share on other sites More sharing options...
BrownTiger Posted March 27, 2019 Share Posted March 27, 2019 The room object has the following properties (attributes ). So technically if you want to get the perimeter, see the example, make sure evaluate is checked ... "Perimeter: " + owner.perimeter.round(0).to_s I am not an architect and this is my hobby. BT ========================================================= ObjectId: NVPublisher ceiling_elevation................................. 201.125 ceiling_finish_layers.......... [NVPublisher, NVPublisher] ceiling_finish_name.......................... Color - Bone ceiling_insulation............................ NVPublisher ceiling_platform_layers..................... [NVPublisher] ceiling_thermal_envelope_area............. 390.89083774113 conditioned.......................................... true conditioned_is_set_to_use_default_value.............. true custom_pattern_scale.................................. 1.0 dimensions................................ 18'-3" x 21'-6" drawing_group.......................................... 35 fill_color_from_background.......................... false fill_color_from_layer................................ true fill_line_weight........................................ 1 finished_ceiling_elevation........................ 200.625 finished_floor_elevation............................ 92.75 floor_elevation...................................... 92.0 floor_finish_layers......................... [NVPublisher] floor_finish_name........................... Secret Garden floor_insulation.............................. NVPublisher floor_number............................................ 2 floor_platform_layers.......... [NVPublisher, NVPublisher] floor_thermal_envelope_area........................... 0.0 function.......................................... Bedroom has_ceiling.......................................... true has_floor............................................ true has_floor_supplied_by_room_below.................... false has_monolithic_slab................................. false has_roof............................................. true has_shelf_ceiling................................... false include_in_living_area............................... true include_in_living_area_is_set_to_use_default_value... true include_in_schedule.................................. true internal_area....................................... 391.0 layer............................................... rooms layer_is_default..................................... true layer_line_color............................... 2151678207 layer_line_style........................................ 0 layer_line_weight...................................... 18 layer_set..................................... Default Set layer_text_style....................... Default Text Style moldings.................................... [NVPublisher] name.......................................... MASTER BDRM pattern_angle......................................... 0.0 pattern_horizontal_spacing............................ 8.0 pattern_vertical_spacing.............................. 8.0 perimeter............................... 952.2245367022674 schedule_number....................................... R29 show_room_label...................................... true simple_schedule_number................................. 29 standard_area....................................... 416.0 stem_wall_height........................ 47.99999999999999 stem_wall_top_elevation.............................. 92.0 transparent_pattern................................. false type_name..................................... Master Bdrm use_type_for_name................................... false volume................................... 3679.56623286403 wall_coverings......................................... [NVPublisher] Link to comment Share on other sites More sharing options...
solver Posted March 27, 2019 Share Posted March 27, 2019 If you make a Room Molding Polyline that takes over the default base molding, you can assign macros to its label. Here I'm showing Visible Length and Perimeter. Note how Perimeter minus the width of the door equals Visible Length. Link to comment Share on other sites More sharing options...
Fotis1960 Posted March 27, 2019 Author Share Posted March 27, 2019 Thanks everyone for your input. I appreciate it. Link to comment Share on other sites More sharing options...
Fotis1960 Posted March 27, 2019 Author Share Posted March 27, 2019 14 hours ago, solver said: If you make a Room Molding Polyline that takes over the default base molding, you can assign macros to its label. Here I'm showing Visible Length and Perimeter. Note how Perimeter minus the width of the door equals Visible Length. How did you get the Visible Length? Link to comment Share on other sites More sharing options...
Kbird1 Posted March 27, 2019 Share Posted March 27, 2019 37 minutes ago, Fotis1960 said: How did you get the Visible Length? It's one of the pre-made Macros you can insert into the Label under Object Specific. Link to comment Share on other sites More sharing options...
Fotis1960 Posted March 27, 2019 Author Share Posted March 27, 2019 3 hours ago, Kbird1 said: It's one of the pre-made Macros you can insert into the Label under Object Specific. Thanks. I don't know how I missed that. I also tried typing it in but forgot to add the _ . I'm learning. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 27, 2019 Share Posted March 27, 2019 Note, if you want to actually perform calculations using those values - you need to have a custom evaluated macro. example: Macro Named "MyCustomMacro" or whatever and your object's visible_length = 498 inches obj = owner x = obj.visible_length/12 x = x.to_s + " ft." The result would be 41.5 ft. That last line make x a string instead of a floating point number. The key here is that Chief's built-in macros display a value but you can't use it for anything else. By creating a macro that accesses the underlying attribute you the capability to manipulate the data and use it for more complex labeling. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 27, 2019 Share Posted March 27, 2019 36 minutes ago, Joe_Carrick said: Note, if you want to actually perform calculations using those values - you need to have a custom evaluated macro. example: Macro Named "MyCustomMacro" or whatever and your object's visible_length = 498 inches obj = owner x = obj.visible_length/12 x = x.to_s + " ft." The result would be 41.5 ft. That last line make x a string instead of a floating point number. The key here is that Chief's built-in macros display a value but you can't use it for anything else. By creating a macro that accesses the underlying attribute you the capability to manipulate the data and use it for more complex labeling. Thanks for the Tips Joe , I was able to make it work , but also rounded it up (.ceil) so it didn't show 9 decimal places ! , so here it is if someone else wants to try it.... Perimeter-Baseboard_add to Room Molding Polyline label.json Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 28, 2019 Share Posted March 28, 2019 Hi Mick, Another possibility is to use .round(3) to get just 3 decimal places max. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 28, 2019 Share Posted March 28, 2019 Just a side note here, but don't forget we can also directly access the actual molding information using macros as well... ...it's a bit more complicated than some of the other stuff though. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 28, 2019 Share Posted March 28, 2019 On 3/27/2019 at 7:53 PM, Joe_Carrick said: Hi Mick, Another possibility is to use .round(3) to get just 3 decimal places max. Thanks Joe, I do appreciate you posting these Macro Tips for those of us who aren't Macro Gurus.... Because it was For Moldings in this case I wanted to round up to the Next Ft , and actually added 1 ft extra too , to make sure I allow for some Waste , 1-2ft extra per Room is nothing really , couple of length per house as I see it , but the Marco is pretty easy to change to Suit each person's needs, or just round it like you suggested, or even to .round(0) and just add your own 10% (?) waste at Final Takeoff instead. M. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 30, 2019 Share Posted March 30, 2019 On 3/27/2019 at 8:20 PM, Kbird1 said: ...or just round it like you suggested, or even to .round(0) and just add your own 10% (?) waste at Final Takeoff instead. Or just skip the polyline steps and automate the whole thing using the actual molding information provided by the room... Molding test.plan Simply drop a copy of the text box into any room you wish to get the molding quantities for that room...and this is just a pretty quick and simple example of the type of information we can automatically pull from the actual model now. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted March 31, 2019 Share Posted March 31, 2019 19 hours ago, Alaskan_Son said: Or just skip the polyline steps and automate the whole thing using the actual molding information provided by the room... Molding test.plan Simply drop a copy of the text box into any room you wish to get the molding quantities for that room...and this is just a pretty quick and simple example of the type of information we can automatically pull from the actual model now. Hey thanks Michael, that works nicely , but I have to say, I think you are probably one of nine guys on this forum who could write that Macro...and understand how it works I made it into a Library "Block" with the Label for Others to use, you just have to remember to "explode" the Block after you insert it , so the macro "reads" the Room it is in , and not just show the Data from the Room I made the Block in. (see pic below) Macro : AlaskanSon_Room Moldings.json CAD Block : MHD_Room Molding CAD Block.calibz Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 31, 2019 Share Posted March 31, 2019 Mick, If you make it a "Note" instead and save that to the Library you can skip the Block. Just put the macro in the "Text above the Line" field of the Note Link to comment Share on other sites More sharing options...
Kbird1 Posted March 31, 2019 Share Posted March 31, 2019 59 minutes ago, Joe_Carrick said: Mick, If you make it a "Note" instead and save that to the Library you can skip the Block. Just put the macro in the "Text above the Line" field of the Note Thanks Joe , I had forgotten that we can now add Notes to the Library , so will give that a try too..... *** there is too much text for the "Text Above Line", for the Callout, so it's better to put the macro in the Text of the Note and have it report in the Schedule, which maybe better anyway as it keeps the drawing "cleaner". M. Link to comment Share on other sites More sharing options...
