ACADuser Posted March 14, 2019 Share Posted March 14, 2019 How do you deal with the end of a railing wall when one is taller? Link to comment Share on other sites More sharing options...
Kbird1 Posted March 14, 2019 Share Posted March 14, 2019 I guess you tried the Wall Edit Tool ..... So next guess would be that the Outer layer in your Wall def. is not the Stucco? ie paint maybe..... Chief only Wraps the very outer layer in the wall def whether that is drywall or stucco or siding etc. M. Link to comment Share on other sites More sharing options...
ACADuser Posted March 14, 2019 Author Share Posted March 14, 2019 This is the best I could do St Pete TH.zip Link to comment Share on other sites More sharing options...
Kbird1 Posted March 14, 2019 Share Posted March 14, 2019 1 hour ago, ACADuser said: This is the best I could do St Pete TH.zip Only trick that works for me is to block the joining with an Invisible Wall set 1/16th or so off the lower wall.... 1 Link to comment Share on other sites More sharing options...
ACADuser Posted March 15, 2019 Author Share Posted March 15, 2019 Sorry I was out. Nice solution. The taller wall is a part of a fire barrier & is required to go all the way over the short wall. I'll try tech support tomorrow. Thanks for the help. Link to comment Share on other sites More sharing options...
gelbuilding Posted March 15, 2019 Share Posted March 15, 2019 14 hours ago, ACADuser said: How do you deal with the end of a railing wall when one is taller? I use slabs for this sort of work around and paint the texture on it. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 15, 2019 Share Posted March 15, 2019 .try to check those railing walls as "Partition walls" in the wall DBX. New tool. . They will not go through Link to comment Share on other sites More sharing options...
ACADuser Posted March 15, 2019 Author Share Posted March 15, 2019 That did not seem to work. I sent to tech support. Thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted March 15, 2019 Share Posted March 15, 2019 3 minutes ago, ACADuser said: That did not seem to work. I sent to tech support. Thanks You want them to go through/over the lower wall now don't you? then the Partition Setting is wrong.... it's used to stop that, I thought you wanted them to stop as well yesterday hence the Room Divider trick..... Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 15, 2019 Share Posted March 15, 2019 Then I guess make a pony wall with the lower a partition wall and the upper not. Link to comment Share on other sites More sharing options...
ACADuser Posted March 15, 2019 Author Share Posted March 15, 2019 Tried that as well, no joy. Link to comment Share on other sites More sharing options...
MarkMc Posted March 16, 2019 Share Posted March 16, 2019 15 hours ago, ACADuser said: Tried that as well, no joy. Here's one way -I run into issues with shower walls all the time, even with the new ones (update your sig to X11 please BTW) I made some symbols that are basically overcoats for walls. Was a solid that was exploded, in my case I made each panel a different material but you don't need that. Then converted to a symbol. I can then place this on top of wall sections allowing for proper 3D look and still get framing (which usually needs a little edit) In this case the stucco material needs to be set to global mapping. Sample with full overcoat on one wall and just the symbol on the other. Is this what you are looking to do? w_overcoat.zip Link to comment Share on other sites More sharing options...
ACADuser Posted March 16, 2019 Author Share Posted March 16, 2019 Thanks Mark, I'll take a look this afternoon. Link to comment Share on other sites More sharing options...
ACADuser Posted March 20, 2019 Author Share Posted March 20, 2019 Tech support could not get it to work. So the developers will take a stab at fixing it. Thanks Mark, that will do for now. Link to comment Share on other sites More sharing options...
