misterwiley Posted February 25, 2019 Share Posted February 25, 2019 I'm wracking my brain on an issue with the callout displayed from a cross-section. In the camera DBX->Plan Display Tab I have unchecked the Display on All Floors options. The callout is showing on floor 1. I would like to move the callout down to floor 0 and not have it shown on floor 1. How do you move an existing camera callout down a floor? This cross section has a bunch of details in it and I would rather not delete it and redraw it on the lower floor, just move its display down a floor. Does anyone know to accomplish this? Thanks for any help. Link to comment Share on other sites More sharing options...
MarkMc Posted February 25, 2019 Share Posted February 25, 2019 AFAIK you can't copy or move to another floor. You can place it on a different layer, then check display on all floors and turn that layer off in plan views (assuming using them) for the floors where you don't want to see it. 1 Link to comment Share on other sites More sharing options...
misterwiley Posted February 25, 2019 Author Share Posted February 25, 2019 In this case, I'm using the same Plan View for all the floors...its the framing set. I guess another solution might be to use the reference floor feature but that seems overly complicated for such a small request. I'm surprised this hasn't been an issue for others yet. Thanks for your suggestion. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 25, 2019 Share Posted February 25, 2019 You might try using a dummy callout. Link to comment Share on other sites More sharing options...
misterwiley Posted February 25, 2019 Author Share Posted February 25, 2019 Just now, Chopsaw said: You might try using a dummy callout. Good idea! This will be a quick solution. Thank you Link to comment Share on other sites More sharing options...
MarkMc Posted February 25, 2019 Share Posted February 25, 2019 11 minutes ago, misterwiley said: In this case, I'm using the same Plan View for all the floors...its the framing set. Change floors, save plan view as-then you have one you can use. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted February 25, 2019 Share Posted February 25, 2019 5 hours ago, misterwiley said: I'm wracking my brain on an issue with the callout displayed from a cross-section. I may be confused. Are you wanting the camera callout on the 1st floor plan to just show on the lower floor plan? If so, when in the cross section view, drop the floor down with the "V" floor arrow and save the section view. It should now show on the lower floor only - "if" you have turned off "show on all floors." 1 2 Link to comment Share on other sites More sharing options...
MarkMc Posted February 25, 2019 Share Posted February 25, 2019 11 minutes ago, Ridge_Runner said: It should now show on the lower floor only - "if" you have turned off "show on all floors." Cool, never knew. Link to comment Share on other sites More sharing options...
misterwiley Posted February 25, 2019 Author Share Posted February 25, 2019 45 minutes ago, Ridge_Runner said: I may be confused. Are you wanting the camera callout on the 1st floor plan to just show on the lower floor plan? If so, when in the cross section view, drop the floor down with the "V" floor arrow and save the section view. It should now show on the lower floor only - "if" you have turned off "show on all floors." OMG you did it! That was the answer, thank you thank you thank you. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 25, 2019 Share Posted February 25, 2019 I'll remember that too....Thanks Mike Link to comment Share on other sites More sharing options...
