rockyshepheard Posted January 19, 2019 Share Posted January 19, 2019 Recently I have been given some good advice that it is better to not make an entrance sign under a gable roof (in another program), import and reposition using either 1. transform/replicate object or 2.open symbol , in favor of doing something like making it with a door and modifying it. So my question is where do you draw the line between doing the (door) technique and making an object outside of CA and doing the import/move in 3D procedure. What about the decorative object under the gable roof, in the photo? Maybe a better way to pose the question is, in general, what objects should better be created outside of CA? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 19, 2019 Share Posted January 19, 2019 There is nothing in that pic that can't be done simple and fast in CA. No need to create symbols. The only time users are going outside of CA to create a symbol is when the symbol they need is very complex, things like light fixtures, furniture or items with contoured surfaces. Before going through the process of creating your own custom symbol you should first check through all of the CA libraries and then say 3D warehouse. Also, before choosing to make a symbol you should consider if an Architectural Block is a better choice. The advantage with Architectural blocks is that all of the elements contained within it are fully accessible and editable. Symbols on the other hand are extremely difficult to edit once created, you can resize the overall symbol but you can't change the items within. 1 Link to comment Share on other sites More sharing options...
rockyshepheard Posted January 19, 2019 Author Share Posted January 19, 2019 I can't think of a way in CA to create the decor under the gable other than going to another plan and creating in 2D and copying it into the main plan, then moving it around in 3D. What is the easy way to do it? Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2019 Share Posted January 19, 2019 There is a Bonus Library with Gable Attachments and a KB Tutorial I think , and a Video on how to make that Truss Detail fairly quickly ( if a little roughly in the Video IMHO) https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/1093 I'll see if I can find the Video , think I was looking at Videos on CAD and Polyline Solids not trusses though..... 1 Link to comment Share on other sites More sharing options...
rockyshepheard Posted January 19, 2019 Author Share Posted January 19, 2019 Thanks, I've just seen the effect of creating in another program a gable bracket and importing into CA. When I export the house to 3DS for import into Lumion, and then import into Lumion, the gable bracket is no longer where it should be. When I do it with the library symbol, it stays in place! Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2019 Share Posted January 19, 2019 36 minutes ago, Kbird1 said: I'll see if I can find the Video , think I was looking at Videos on CAD and Polyline Solids not trusses though..... found it......Probably good to watch the whole video but the Gable decoration or Truss starts at about the 12min. https://www.chiefarchitect.com/videos/watch/77/cad-basics.html?playlist=97 Once made it is pretty easy to turn into a symbol , by copy pasting into a new plan and converting to symbol while in a 3D view. 1 Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 19, 2019 Share Posted January 19, 2019 Just create a polyline solid as a large triangle say 1 1/2" thickness on the gable face and then create 4 triangular holes in it. Link to comment Share on other sites More sharing options...
SNestor Posted January 19, 2019 Share Posted January 19, 2019 this video may help you... 1 2 Link to comment Share on other sites More sharing options...
rockyshepheard Posted January 19, 2019 Author Share Posted January 19, 2019 1 hour ago, TheKitchenAbode said: Just create a polyline solid as a large triangle say 1 1/2" thickness on the gable face and then create 4 triangular holes in it. Holes? Link to comment Share on other sites More sharing options...
parkwest Posted January 19, 2019 Share Posted January 19, 2019 That gable decoration in the op can be done in about 2 seconds using a standard truss and edit the chords to meet your needs. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2019 Share Posted January 19, 2019 10 minutes ago, rockyshepheard said: Holes? Watched the video? Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 19, 2019 Share Posted January 19, 2019 8 minutes ago, rockyshepheard said: Holes? Just draw a polyline solid, click on it to select, the last (right) icon bottom of your screen is the create hole function. Just click on it and you can draw a polyline hole in your polyline solid. The hole can be manipulated just like any other polyline. You can place as many holes as you wish as long as they do not overlap another hole or extend outside of the main polyline solid. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2019 Share Posted January 19, 2019 1 minute ago, parkwest said: That gable decoration in the op can be done in about 2 seconds using a standard truss and edit the chords to meet your needs. Have used that trick a time or two myself...... Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 19, 2019 Share Posted January 19, 2019 Here's a quick example, Polyline Solid with three holes in it. Thickness set to 1 1/2". Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 19, 2019 Share Posted January 19, 2019 I made it 8" thick, pulled it forward, extended the roof, added 2 columns and a slab porch. Link to comment Share on other sites More sharing options...
rockyshepheard Posted January 19, 2019 Author Share Posted January 19, 2019 2 hours ago, SNestor said: this video may help you... Yes, very helpful! thanks. Link to comment Share on other sites More sharing options...
