MCADNZ Posted January 15, 2019 Share Posted January 15, 2019 Hello to All, We currently have a client that supplies conceptual designs to us in archicad PLN file formats, is there any way we can convert or import these files into chief without going the DWG route. Any help would be greatly appreciated, Cheers Link to comment Share on other sites More sharing options...
lbuttery Posted January 15, 2019 Share Posted January 15, 2019 If you have Chief look at MENU - FILE - IMPORT and verify which formats can be imported Lew 3 1 Link to comment Share on other sites More sharing options...
Richard_Morrison Posted January 15, 2019 Share Posted January 15, 2019 No, there isn't. You will need to ask for DWGs. EDIT: I've used both Chief and ArchiCAD for about 20 years each, and go back and forth between the two all the time. It's kind of sad to give someone correct information and get downvoted for it. Reminds me of Jack Nicholson: "You can't handle the truth!" 1 5 Link to comment Share on other sites More sharing options...
mkwajungozi Posted July 19, 2021 Share Posted July 19, 2021 Hello to all, I have a question. When i used Arxhichad, it was so much easier to shift between scales. Now im using chief archichad, i find it difficult to shoft from feets to metres. How do i change this scale ? Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 19, 2021 Share Posted July 19, 2021 42 minutes ago, mkwajungozi said: Hello to all, I have a question. When i used Arxhichad, it was so much easier to shift between scales. Now im using chief archichad, i find it difficult to shoft from feets to metres. How do i change this scale ? You are going to have to be a little more distinct with your query to obtain useful answers and understanding for yourself from others. The "Scale" of what and where, doing what please? DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted July 19, 2021 Share Posted July 19, 2021 3 hours ago, mkwajungozi said: i find it difficult to shift from feet to metres. How do i change this scale ? You can't in a plan that is already drawn ( you could display both if needed with the secondary format.) to Start a Metric Plan , Start by Opening the Plan from Template > and open ResidentalM.plan file ( the M on the end of names indicates Metric templates. ) Link to comment Share on other sites More sharing options...
mkwajungozi Posted July 20, 2021 Share Posted July 20, 2021 As a starter, how do i draw a plan in metres? Link to comment Share on other sites More sharing options...
Chopsaw Posted July 20, 2021 Share Posted July 20, 2021 3 minutes ago, mkwajungozi said: As a starter, how do i draw a plan in metres? 12 hours ago, Kbird1 said: to Start a Metric Plan , Start by Opening the Plan from Template > and open ResidentalM.plan file ( the M on the end of names indicates Metric templates. ) Link to comment Share on other sites More sharing options...
mkwajungozi Posted July 20, 2021 Share Posted July 20, 2021 15 hours ago, DavidJPotter said: You are going to have to be a little more distinct with your query to obtain useful answers and understanding for yourself from others. The "Scale" of what and where, doing what please? DJP I installed chief architect a while ago, i dont feel comfortable drawing a house plan using feet as a scale for both internal and external dimensions. So my question is, how do i change these scales from to metres in chief architect since a new plan opens with feet dimensional scale Link to comment Share on other sites More sharing options...
Chopsaw Posted July 20, 2021 Share Posted July 20, 2021 3 minutes ago, mkwajungozi said: So my question is, how do i change these scales from to metres in chief architect since a new plan opens with feet dimensional scale Go to File> New Plan from Template. You can set this as your default in Preferences> General> New Plans. Link to comment Share on other sites More sharing options...
lbuttery Posted July 20, 2021 Share Posted July 20, 2021 It's kind of sad to give someone correct information and get downvoted for it. I feel the same about giving an opinion downvotes are for children and those with petty grievances Lew 3 1 Link to comment Share on other sites More sharing options...
SteveJepson Posted August 25, 2021 Share Posted August 25, 2021 On 1/14/2019 at 5:31 PM, MCADNZ said: Hello to All, We currently have a client that supplies conceptual designs to us in archicad PLN file formats, is there any way we can convert or import these files into chief without going the DWG route. Any help would be greatly appreciated, Cheers Link to comment Share on other sites More sharing options...
SteveJepson Posted August 25, 2021 Share Posted August 25, 2021 .skp files are as useful as any to use for getting ArchiCAD 3D content into Chief Architect programs. And for the 2d content both programs have some sort of .dwg Translators which could be configured to work pretty well together. ArchiCAD can import a .pdf and explode it into lines, polylines, hatch, text.... and if the .pdf was generated with AutoCAD or ArchiCAD, layers, layer combos, and some other content is also available that way too. I have very little experience with Cheif Architect but what I have seen of it and the Home Designer program, I am not impressed too much. But I do like the user interface the Home Designer has. It seems pretty easy to use. Link to comment Share on other sites More sharing options...
