Outside Corner - Pony Wall Alignment
ChiefChris1
The attached image shows the front wall as a pony wall aligned on the inner surface.
I am using Chief's standard wall types.  (2x4 with vinyl upper and brick lower).
The side wall is brick and it is not generating the outside corner properly.  I can see the wall sheathing on the upper and the brick doesn't make a corner.
It does it properly when the side wall is siding.
Any thoughts on why it's not connecting the outside corner right?
15 minutes ago, solver said:
Not sure how the siding/brick should join, but like Michael said, the Edit Wall Layer Intersection tool might work.
For the brick, make the side wall a Pony Wall, brick over brick with the lower part matching the height of the front wall.
It can totally be done with a normal wall too...
26 minutes ago, solver said:
Another way ...
Good thought, but I would take a closer look at that one.  I think you'll find that you still need to use the Edit Wall Layer Intersection tool.   I typically work in vector view specifically so that I see whats really going on and catch those issues right away.
On a construction and design note I would consider returning the brick upper around the corner a bit or adding a some sort of a heavy corner board detail.
In my experience the exposed joint from lap siding to brick at that location can be a water infiltration issue- and if it gets behind there and freezes -POP goes the masonry.
Just a thought ;)
Just a thought ;)
Rob.  It's for an As-Built...so, I model it the way it IS, not the way it should be.  ;)
