rockyshepheard Posted December 18, 2018 Share Posted December 18, 2018 Trying my hand at 100% manually built roof. Problem: all planes were created on a wall that is the same height all the way around but one section has extra height added somehow. All have 9' ceiling height. Thank you INDIANA6 outside test no upper 2forum.plan Link to comment Share on other sites More sharing options...
rlackore Posted December 18, 2018 Share Posted December 18, 2018 Your Roof Baselines are floating in space: Select the baseline and drag it up to the wall's main layer: This will correct the height of the roof plane, which you can then join to the other planes: I highly suggest you download a copy of the Reference Manual and study the chapters on roof planes. Link to comment Share on other sites More sharing options...
rockyshepheard Posted December 18, 2018 Author Share Posted December 18, 2018 Thank you. How can one tell which plane belongs to a baseline if the baseline has the ability to move away from its plane. Not sure how that baseline moved from the edge of the wall? Highlighting the baseline does not highlight the plane. Link to comment Share on other sites More sharing options...
rlackore Posted December 18, 2018 Share Posted December 18, 2018 On 12/18/2018 at 8:13 PM, rockyshepheard said: Highlighting the baseline does not highlight the plane. Expand No, but selecting the Roof Plane will highlight its baseline. I set the Roofs, Baseline layer to a bright green color and a dashed line style; this helps me identify the baselines, especially when they are highlighted. 1 Link to comment Share on other sites More sharing options...
glennw Posted December 18, 2018 Share Posted December 18, 2018 On 12/18/2018 at 8:21 PM, rlackore said: No, but selecting the Roof Plane will highlight its baseline. Expand Robert, Is that correct? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 18, 2018 Share Posted December 18, 2018 On 12/18/2018 at 9:56 PM, glennw said: Robert, Is that correct? Expand It is correct Glenn. It's just not very noticeable with the Selection Line color that most of us use. Try changing your Selection Line color (Preferences) to bright blue or bright red and then give it a quick test. Link to comment Share on other sites More sharing options...
dshall Posted December 18, 2018 Share Posted December 18, 2018 On 12/18/2018 at 10:37 PM, Alaskan_Son said: It is correct Glenn. It's just not very noticeable with the Selection Line color that most of us use. Try changing your Selection Line color (Preferences) to bright blue or bright red and then give it a quick test. Expand hmmmm.... not sure about that..... can I see a pic of a roof plane selected with a green color fill & a base line color of red? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 18, 2018 Share Posted December 18, 2018 On 12/18/2018 at 10:58 PM, dshall said: hmmmm.... not sure about that..... can I see a pic of a roof plane selected with a green color fill & a base line color of red? Expand No Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 18, 2018 Share Posted December 18, 2018 The point is that the baseline is highlighted along with the roof plane. Robert changed his baseline layer color to bright green because it makes the baseline much more obvious when it is highlighted. Not because it turns the baseline bright green but because the highlighted baseline looks so much different than the rest of the bright green baselines. Link to comment Share on other sites More sharing options...
tommy1 Posted December 18, 2018 Share Posted December 18, 2018 Rocky, the replies above are correct. Here is a reminder of what I recommended you to do when drawing a roof plane manually. 1. Set the pitch you want to use for that roof plane and the overhangs if you want. Overhangs can be changed later though. 2. Turn on the angle snap so you're drawing straight. 3. Be sure the "on angle snap" is turned on so that when you're starting the roof plan, it will snap to the outside of main layer (assuming you didn't change the AltQ setting or general wall default setting which by default it will be set for outside of main layer). 4. Be sure you're zoomed in close enough to the wall to that you can see that you're snapping to the outside main layer. Doing these steps will help a lot. Also remember that the roof plate height is based off of the room "rough ceiling height" shown for that room where you're starting the roof plane which is located in that room dbx. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 18, 2018 Share Posted December 18, 2018 On 12/18/2018 at 10:58 PM, dshall said: hmmmm.... not sure about that..... can I see a pic of a roof plane selected with a green color fill & a base line color of red? Expand On second thought, I guess I didn't think about your post well enough. I was thinking you were talking about 2 different line colors. You're talking about a line color and a fill color. Yes, your request is possible... Link to comment Share on other sites More sharing options...
glennw Posted December 18, 2018 Share Posted December 18, 2018 I cannot see how selecting the roof plane also selects the baseline. Here are 2 pics - one showing the roof plane selected (the baseline is not selected), and the second pic shows the baseline selected (the roof plane is not selected). I cannot see any other pictures, nor can i get the baseline to be selected by selecting the roof plane. PS, maybe we are talking about cross purposes here. If you select a roof plane and move it, the baseline will move with it. The baseline isn't selected in the traditional sense that it has selection grips like the roof does when it is selected. I guess it depends on what "selected" means. eg, you can't select a roof plane and expect the baseline to be selected for individual editing independent of the roof plane. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 18, 2018 Share Posted December 18, 2018 Glenn, We're not talking about "selected". We're talking about "highlighted"...so that you know which baseline belongs to which roof plane. Try changing your roof baseline color to something like yellow and the select a roof plane. 1 Link to comment Share on other sites More sharing options...
glennw Posted December 18, 2018 Share Posted December 18, 2018 On 12/18/2018 at 11:50 PM, Alaskan_Son said: We're not talking about "selected". We're talking about "highlighted". Expand OK, I get the distinction now. Link to comment Share on other sites More sharing options...
dshall Posted December 19, 2018 Share Posted December 19, 2018 On 12/18/2018 at 11:34 PM, Alaskan_Son said: On second thought, I guess I didn't think about your post well enough. I was thinking you were talking about 2 different line colors. You're talking about a line color and a fill color. Yes, your request is possible... Expand Of course, not sure what I was thinking, thx in a working set I also make baseline line weight very heavy to help identify. Link to comment Share on other sites More sharing options...
