basilbabaa Posted December 11, 2018 Share Posted December 11, 2018 When starting a preliminary site plan, in addition to the boundary survey and topographical map, I often include a scaled shot from Google Earth/Maps. I paste the Shot in and draw the building envelope onto of the pasted overlay. It would be nice to be able to reduce the pasted images' transparency/opacity so it is not so overbearing. Any current way in Chief to do so without having to run it through photoshop first, like I did in the attached file....? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 11, 2018 Share Posted December 11, 2018 Here's my personal approach. Send to the back drawing group. Draw a Polyline or CAD box over the top, set the fill style to solid>background color, and give it a transparency Send the Polyline to the back drawing group and then Move Forward In Group Link to comment Share on other sites More sharing options...
Mark3D Posted December 11, 2018 Share Posted December 11, 2018 4 minutes ago, Alaskan_Son said: Here's my personal approach. Send to the back drawing group. Draw a Polyline or CAD box over the top, set the fill style to solid>background color, and give it a transparency Send the Polyline to the back drawing group and then Move Forward In Group Good idea thanks Micheal I have been struggling with problem also Link to comment Share on other sites More sharing options...
Chopsaw Posted December 11, 2018 Share Posted December 11, 2018 1 hour ago, basilbabaa said: It would be nice to be able to reduce the pasted images' transparency/opacity so it is not so overbearing. Any current way in Chief to do so without having to run it through photoshop first, like I did in the attached file....? Apply the Satellite shot as your Watermark. Image transparency is unfortunately hidden away in only that part of the program. Link to comment Share on other sites More sharing options...
Mark3D Posted December 11, 2018 Share Posted December 11, 2018 35 minutes ago, Chopsaw said: Apply the Satellite shot as your Watermark. Image transparency is unfortunately hidden away in only that part of the program. i cant see a way to scale it with this method correct me if i am wrong Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 12, 2018 Share Posted December 12, 2018 I thought transparency's were available with PNG images only Link to comment Share on other sites More sharing options...
Chopsaw Posted December 12, 2018 Share Posted December 12, 2018 3 hours ago, Mark3D said: 3 hours ago, Chopsaw said: Apply the Satellite shot as your Watermark. Image transparency is unfortunately hidden away in only that part of the program. i cant see a way to scale it with this method correct me if i am wrong Yes that may be difficult to do accurately. There is a "Ratio to Sheet:" setting but it is only in increments of 1%. If you don't have a photo editor you could use the Watermark feature to set the transparency and export as an image and then re-import and scale accurately. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 12, 2018 Share Posted December 12, 2018 P.S. You can also turn the brightness up on the image to get a similar effect. Link to comment Share on other sites More sharing options...
