Cheryl_C_Crane Posted September 4, 2014 Share Posted September 4, 2014 Does anyone have a Washer Outlet Box that they could share? I thought that we had one in the Library, but my searches are not pulling results. Many Thanks in advance! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 4, 2014 Share Posted September 4, 2014 Cheryl, I'll try to create one this evening. It will be like most such symbols - needing to be placed within a "Pass-Thru" Window opening in the wall. - unless I can do it with a Window Symbol. Link to comment Share on other sites More sharing options...
Cheryl_C_Crane Posted September 4, 2014 Author Share Posted September 4, 2014 Thanks for the assist, Joe! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 7, 2014 Share Posted September 7, 2014 Hi Cheryl,Sorry I got tied up and forgot about this. Here's a symbol that should work for you. It's set to mount on a wall 42" above the floor but you will need to provide an 8"x 6" pass-thru window at 42" above the floor and move the symbol 3-7/8" into the opening.If the wall is exposed on the opposite side you will need to put a Solid into the Pass-Thru on that side to fill the hole in the wall finish material. Washing Machine Outlet Box.calibz Link to comment Share on other sites More sharing options...
dshall Posted September 7, 2014 Share Posted September 7, 2014 Hi Cheryl, Sorry I got tied up and forgot about this. Here's a symbol that should work for you. I't set to mount on a wall 42" above the floor but you will need to provide an 8"x 6" pass-thru window at 42" above the floor and move the symbol 3-7/8" into the opening. If the wall is exposed on the opposite side you will need to put a Solid into the Pass-Thru on that side to fill the hole in the wall finish material. Thanks JC, very nice. Hopefully with X7 we will be able to provide niches. OTH, not too tough with the symbol you provided. Hope the back is better. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 7, 2014 Share Posted September 7, 2014 Thanks JC, very nice. Hopefully with X7 we will be able to provide niches. OTH, not too tough with the symbol you provided. Hope the back is better. Niches should be fairly simple - CA could use their subroutines for "Wall Material Region" to cut holes in the wall layers as thick as the niche recess. It might require a new Symbol Class or it could just be a flag and y-origin adjustment. IAE, I agree that this feature is long overdue. My back is better - I got a cortisone injection for a pulled muscle. Still some pain but not too bad. Link to comment Share on other sites More sharing options...
lbuttery Posted September 7, 2014 Share Posted September 7, 2014 or clone the pass-thru tool and have a setting for which side to place the "back" on Lew Link to comment Share on other sites More sharing options...
Cheryl_C_Crane Posted September 7, 2014 Author Share Posted September 7, 2014 Joe, This is WONDERFUL! Thank you so much. I've had 11 hours of back surgery in the last 6 months. I now have a 15 level fusion and am doing pretty well. Guess that you could say I'm a lucky stiff. Take care of your back & Thanks, again. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted September 8, 2014 Share Posted September 8, 2014 Thanks JC! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 8, 2014 Share Posted September 8, 2014 Here is another Version of the Symbol. This one auto-magicly creates a pass thru for you - but you might have to adjust the height above the floor. In addition, if it is on the wrong side of the wall, you would need to rotate the symbol about the z axis and adjust the y origin (both of those edits would be in the general tab of the symbol dbx. In the Pass-Thru Window dbx, suppress the Frame. Washing Machine Outlet Box-AutoInsert.calibz Link to comment Share on other sites More sharing options...
CJSpud Posted September 8, 2014 Share Posted September 8, 2014 Thanks Joe. I thought I might have one Tommy posted a couple of years ago but couldn't find. Now I am good to go. As a matter of fact, I am going to take that puppy and plop it into the laundry room of the project I have open. Sorry to hear your back is giving you some grief. Hope your problem goes away soon. Link to comment Share on other sites More sharing options...
Cheryl_C_Crane Posted September 8, 2014 Author Share Posted September 8, 2014 Joe, Thanks again! Your time is valuable, and I appreciate you using it to fill a need. KUDOS! Link to comment Share on other sites More sharing options...
CJSpud Posted September 8, 2014 Share Posted September 8, 2014 I found the one that Tommy Blair posted on the old forum some time ago. I was on my old computer's HD. T Blair Water Connection.calibz Thanks again Tommy. 1 Link to comment Share on other sites More sharing options...
Cheryl_C_Crane Posted September 8, 2014 Author Share Posted September 8, 2014 Curt, I just KNEW that there was one in the Library some time back. Thanks for looking, I don't feel quite as crazy. Maybe just a little... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 8, 2014 Share Posted September 8, 2014 Tommy used a Doorway - I used a Window Pass-Thru. I haven't been able to get Tommy's to display as anything but black - don't know why. Link to comment Share on other sites More sharing options...
CJSpud Posted September 9, 2014 Share Posted September 9, 2014 Joe: This is what it looks like if you use the exterior wall option: Link to comment Share on other sites More sharing options...
CJSpud Posted September 9, 2014 Share Posted September 9, 2014 The valve box we have in our laundry room has a single "lever" handle in the center that operates both valves. I don't know if that's good or bad but we've never had any issues with it. Link to comment Share on other sites More sharing options...
tommy1 Posted September 9, 2014 Share Posted September 9, 2014 Tommy used a door - I used a Window Pass-Thru. I haven't been able to get Tommy's to display as anything but black - don't know why. Joe, mine looks fine no matter which one I use on my computer. Don't know why you're seeing black. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 9, 2014 Share Posted September 9, 2014 I think it's because it was created in an earlier version and the materials simply didn't come into X6 when I imported the symbol. I edited all the materials and now it looks OK. IAE, the size doesn't match what I have at HD and Lowes, Link to comment Share on other sites More sharing options...
tommy1 Posted September 9, 2014 Share Posted September 9, 2014 It matched the size from Lowe's here back when I made it several years ago. Things change. Link to comment Share on other sites More sharing options...
Arbiter Posted October 15, 2017 Share Posted October 15, 2017 On 9/8/2014 at 0:39 PM, Joe_Carrick said: In addition, if it is on the wrong side of the wall, you would need to rotate the symbol about the z axis and adjust the y origin (both of those edits would be in the general tab of the symbol dbx. Thanks for making this, Joe. I don't understand how to rotate the symbol about the z-axis. What's a dbx? dialog box? Perhaps my version of Chief Architect (Home Designer Architectural 2018) doesn't include this option for rotating around the z-axis? Link to comment Share on other sites More sharing options...
tommy1 Posted October 20, 2017 Share Posted October 20, 2017 I do my water connections different now in X9. I use the new niche tool in X9. Size it and place it where I want. I created a new "symbol" that I use. I place the symbol in the plan, set the height off the floor and control drag it into the niche. The symbol shows in the plan view so no cad block representation is needed. I attached the X9 library if anyone is interested in using this method. Side note: In the library for the symbol, I have the box dimensions shown that I use but any box size could be used. T Blair X9 water connections.calibz 3 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 20, 2017 Share Posted October 20, 2017 Thanks Tommy. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted October 20, 2017 Share Posted October 20, 2017 Thanks! Link to comment Share on other sites More sharing options...
jscussel Posted October 20, 2017 Share Posted October 20, 2017 Thanks, Tommy........... Link to comment Share on other sites More sharing options...
