Rope Light on ceiling soffits
Aamir77
I have tried to make the rope light above ceiling soffits with surface mounted tube lights used as floor mounted lights (red arrow signs in pic# 2). In ray tracing lights are showing pointed with gapes among them(pic #1) whereas I have wanted to make its smooth continuity along the ceiling soffits.Any clue how to make such a rope light?
I just imitated it in rendering with a high-intensity emissive property solid bar (in pic #3) which does not lit up in ray trace.
Any solution?
19-7.thumb.jpg.3e2605c9b67436077cf7610f6d14c699.jpg5b8403f708444_19-sample-Copy.thumb.jpg.fb4cb71f74815df6ab9dd41ec1e885e1.jpg18-15.thumb.jpg.9274a67f56737a5696d863b959b8623b.jpg
9 minutes ago, rlackore said:
You should be able to just click on the link (or right click>save link as). It downloads fine for me.
Thanks Robert, it actually tries to load in to X9. I'll see if can use it from there. But won't open, says it was written by a later version - too funny. Laughing at myself.
Changed the association in Win 10 and imported fine. Haven't looked at it yet - thanks. Wow have no idea how you did but it' pretty cool. Not so cool that it takes that much work to create a very common light source.
This is a known Issue with X10 , it does not update the File Associations to X10 for the Library items etc , has been happening with my posted Libraries too.
On 8/27/2018 at 7:48 PM, HumbleChief said:
Information in these links does not provide the solution to make the simulated light glow during the Ray Trace. Somehow I tried to tweak with the settings and get as close as I18-18.thumb.jpg.4ce3c28a86e8b91802c5399f5cf581b6.jpg could but irritating part is the glow just at the centre of each light source.
Yes, as I said in the third post above, Again, sorry I'm could not be of more help to you.
Perhaps Robert can share his technique to create rope lights?
On 8/27/2018 at 11:48 AM, rlackore said:
The best you can do is create many closely-spaced lights and adjust their illumination properties until you achieve a satisfactory result. You will have to compromise between rendering speed and appearance.
AFAIK, this is the only answer. There is no easy, automated solution - you simply have to bite the bullet and do the work.
  • 2 weeks later...
