brushpark Posted June 8, 2018 Share Posted June 8, 2018 Working on an electrical plan and find the wire connections difficult to organize. The wire ends pop in not centered or on the fixture symbol. I find myself spending a lot of time moving the wires to make them make sense on the drawings for the electrician. Does anyone else have this problem or am I doing something wrong? Thanks, Tom Link to comment Share on other sites More sharing options...
Richard_Morrison Posted June 8, 2018 Share Posted June 8, 2018 If you do a search on the forum using the phrase "electrical connections" (using the quotation marks), you can find out, and also get some suggestions. Link to comment Share on other sites More sharing options...
brushpark Posted June 8, 2018 Author Share Posted June 8, 2018 I did a search on "electrical connections" and nothing came up except my post? Link to comment Share on other sites More sharing options...
JLDrafting Posted June 8, 2018 Share Posted June 8, 2018 just tried without the Quotes and it worked. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted June 9, 2018 Share Posted June 9, 2018 Brushpark, You need to search the forum, not "This topic". You can see what you are searching just to the left of the search field. If you use quotation marks, you get the search for the phrase; without the quotes you get everything with electrical OR connections, which is too much. Link to comment Share on other sites More sharing options...
mtldesigns Posted June 9, 2018 Share Posted June 9, 2018 To answer your question brushmark (my fellow Michigander).. its not just you. You fill find many comments on this, including mine from the past. It is what it is.. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 9, 2018 Share Posted June 9, 2018 26 minutes ago, mtldesigns said: It is what it is.. Yes for now and in X9, but lets keep pushing for improvement. It is long overdue in this department. Link to comment Share on other sites More sharing options...
Kelly_K Posted June 9, 2018 Share Posted June 9, 2018 18 hours ago, Chopsaw said: ... It is long overdue in this department. Let's put some time frame to this comment, while not great, the arcs worked better with version 9.5 than they do now. I've been waiting in consternation for 15 years for any improvement. Link to comment Share on other sites More sharing options...
Electromen Posted June 11, 2018 Share Posted June 11, 2018 I'm an electrical contractor and use CA specifically for electrical drawings. I've been asking for better control and more layers since '97. Very little has changed since then. Link to comment Share on other sites More sharing options...
