Access to wall hatching tool defaults?
Renerabbitt
Love the wall hatching tool, I find it to be far more efficient than changing wall types for new walls, but I always end up changing the hatch to fill. I've even set up a wall hatching layer set with just wall hatching on so I can use the object painter and change to fill. All because I can't find the default dbx so I can change it as a global parameter. Anyone know how to accomplish this?
Even though there is no default, after you place it , you can select it and change the hatching. to select all wall hatching, just hold down the shift key while the wall hatching is active , draw a box around all the floor plan to select all hatching in the plan.
There you go,  Perry has a fairly easy solution to get what you want.
Nice job P.
