A door that doesn't open
robdyck
Does anyone know how to show a door in elevation view without an opening indicator. Example, a fixed sidelite as part of an entry door unit. I currently just delete the line with the 'edit layout' tool. Obviously this little task has to be repeated...
need to explode the mulled unit and set the sidelite to fixed and then re-mull the unit
I don't think there's any good way to do that and still leave the sidelite as a door.  I think your best bet is to just make the sidelite a doorway and place the door panel manually (as a freestanding symbol).
This is the most often used way for me. It is quick unless there are several of these to do -- or you are editing the view often and have to do this over and over. I wish we had a way to turn these off per instance if needed.
15 hours ago, solver said:
Where is this fixed setting you refer to?
Solver you're absolutely right, I was missing a ton of steps.
In past I have used the delete surface tool with hidden hinges and removed hardware and then convert the door to a window symbol..which is why I was remembering setting something to "fixed"
Here is a mulled unit with the sidelite as a window using the method mentioned above. mulled door and sidelite.calibz
You can see in elevation it shows as intended:
and in 3d:
My main problem is with insertion points and offsets with how the cad generated block shows...which is why I reposted Alaskan as I feel as if he would have the solution to that part of the problem:
That is one of many reasons I very rarely use window symbols for anything.  I'd typically rather just cut the opening (using material regions, a doorway, or a pass through) and then place the symbol as a regular fixture.  And now, in X10 we have the new Inserts Into Wall option which basically gives you the cutout and the symbol all in one.
Your window method intrigues me. I've played around with developing my own window symbols but haven't had the time to complete anything. That would really help with accurate modelling as I do a lot of my details in 3D.
in this case it might be best to draw a WHITE LINE over them opening indicator.  Still a bit tedious but at least it hides the indicator if the view is updated.
  • 2 weeks later...
    30642
    oppguenard1
    oppguenard1
  • Similar Content
    • By BlueEyeInteriors
      Hello, I often time need to draw just one room not the entire Floorplan. In these situations the doorways leading in and out of the rooms show the landscape outside. How can I remove the landscape shown around a room from different angles without having to draw temporary walls around the rooms entry points.
      For example the arch opening in this screenshot is supposed to lead to another room but I am only focused on this space. Do I have to draw the entire space or can I edit what is seen from that doorway?
    • By Reelfast1
      We use X9 version. Is there a way to cut into a wall that's up against stairs going up and have a opening without using a doorway and make it follow the line of the stairs? See attached photo. The blue line shows where I want the opening to be done and it will be finished with drywall and will have no trim work or doorway opening. It will just be open. Thanks in advance.
    • By SteveByars
      How can I create an L-shaped wall opening as shown in the attached picture? I've tried mulling doors and windows together but always get a section of wall/frame between them.
      thanks!
    • By yusuf-333
      Here is a video on how to mix the tools of chief to get the detailed framing for a wall with curved opening. This isn't the only way but one way to get the job done. Hope it helps.
      On a side note, I tried to show some work flows that could help during chief model and symbol creation as well.
    • By ChiefBe
      Hello
      I am trying to open multiple brick walls with large openings supported by posts and beams. The exterior wall will then have multiple adjacent windows, all connected to each other.
      However I can't manage to do this with Chief Architect.
      When using a window, he doesn't allow me to continue the window, passing the perpendicular wall.
      I tried to use posts and beams, however I can't find a way to say that the upper wall is carried by that post/beam and there's no need to keep a small part of wall to carry everything.
      As pictures say a lot more than words, on the left what I can do, and on the right I would like to do:
      Any advice on forcing ChiefArchitect to draw windows past the perpendicular wall is definitely welcome !
      Thanks
