Punch a hole in a psolid?
ACADuser
I was able to create the p-solid in plan view & add the hole.
Then creating the turn down p-solid and converted them both to Solids.
Only then could I move them together.
While they were p-solidsI could not use the point to point move as only one or the other would allow a snap selection point.
As Solids I was able to move then together but they will not UNION.
Wow
Does it bother anyone else that there is NO command line feedback from Chief when you enter a command or hit UNDO.
In AutoCAD when you enter a command it tells you if the command was successful or gives an error.
When you undo it tells you what command was undone.
I feel like I'm in that dark with Chief.
